Nails Protruding Through Studs In Area To Be Wired - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2010, 11:07 AM   #1
Nails protruding through studs in area to be wired
Framing an addition near corners and door openings builder doubled-up on many studs by nailing. Nails were too long and protrude into the area where wiring and switches will be installed, poking our nearlhy a quarter inch about every 6 inches or so. Is this a common or legal? Even if I successfully navigate around nails, will having them protrouding so close to romex cable and switches cause problems with safety or inspection? Please advise.
Mi Feller is offline   Reply With Quote
Old 06-05-2010, 11:33 AM   #2
Here's some additional details. Nails actually protrude closer to half inch in places. Most were put in side-by-side leaving center of stud clear. Am guessing as long as I staple (using stackers) right in center of stud I'll clear enough nails to so the work. Is that OK as far as anyone knows?
Old 06-05-2010, 12:57 PM   #3
Rewards Points: 502
I've got to think it would be. nail sticking though sheeting are very common.
forresth is offline   Reply With Quote
The Following User Says Thank You to forresth For This Useful Post:
Mi Feller (06-05-2010)
Old 06-05-2010, 08:40 PM   #4
Rewards Points: 1,910
Smack them over with a hammer so the points embed in the lumber pointing away from the wire path.
The Following User Says Thank You to jogr For This Useful Post:
Mi Feller (06-06-2010)
Old 06-05-2010, 09:27 PM   #5
Registered User
Rewards Points: 5,482
Yes, they are legal, and exceed minimum code. I double nail also, and angle each set opposite for maximum holding power when the framing starts to shrink when the permanent heat source is on. As you discovered, the wiring needs to be set back min. 1-1/4" from the face, so the drywall fasteners don't hit. That is quality work! Sounds like above minimum code (3"-10d) for nail length.
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 06-06-2010, 07:43 AM   #6
Rewards Points: 1,494
If you smack the nail over, it may bend over gradually, elongating the hole it was in and lessening its holding power in the stud.
Would it be a problem glueing a piece of wood next to the nail point for the wires to pass over?
The Following User Says Thank You to AllanJ For This Useful Post:
Old 06-06-2010, 07:53 AM   #7
Thanks to All. Will work around nails and only bend one if absolutely necessary. Yes, a quality builder and construction looks like it would withstand an earthquake - not a big concern in Michigan.
Old 06-06-2010, 08:37 AM   #8
Handyman
Rewards Points: 512
Is there room enough to get an angle grinder with a cut off blade? Or even a sawzall with a metal blade to cut the nail excesses off?
canadaclub is offline   Reply With Quote
Old 06-06-2010, 09:49 AM   #9
Sounds like they used 3.5" nails straight thru instead of 3" nails
3.5" angled down/up enough would not have penetrated
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
9 foot span ok for metal studs as ceiling joists? Garasaki Carpentry 7 08-22-2008 09:12 AM
Reattaching baseboards? Joony Flooring 7 07-06-2008 08:11 AM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 10:57 AM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
