Nail Guards - Electrical - DIY Chatroom Home Improvement Forum
Old 07-21-2008, 04:33 PM   #1
Nail Guards
Anyone have a source for "oversized" nail guards. I am working in a 100 year old property and the wall studs are a true 2" width. All the nail guards I have been able to find are for standard, modern 2x studs. Have thought about using a metal plate (like the back of a box) and screwing it in above and below the wire hole but as you can imagine that will be a lot more work than a pre-made nail guard. Thank you for your help.
phillyexplorer is offline   Reply With Quote
Old 07-21-2008, 05:39 PM   #2
Master Electrician
JohnJ0906's Avatar
I have seen them, and even used them recently, but can't remember the brand.
They say memory is the second thing to go..... I can't remember the 1st....
I'll ask at the shop tomorrow if someone doesn't chime in.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 07-21-2008, 06:06 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I can't remember either John....
However I believe he will find what he is looking for in the plumbing department. They usually have 3 or 4 sizes of nail guards in a good store.
Old 07-21-2008, 06:22 PM   #4
Electrician
They are called Boca Plates. SIOUX CHIEF is one manufacture of them.
chris75 is offline   Reply With Quote
Old 07-21-2008, 08:11 PM   #5
Thanks for the tips on checking the plumbing department. I looked at the BOCA plates - I am looking for a plate that is a true 2" wide. Anyone know of a source for a 2" wide plate? Otherwise, I imagine I will need to review using a 3" plate with my inspector.
Old 07-21-2008, 08:30 PM   #6
Registered User
Termite's Avatar
BOCA plates are something like 5x7.
Old 07-21-2008, 08:34 PM   #7
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
Are you just fishing this wire through the walls if so i dont beleive that you need these or have to staple the wire.
Pudge565 is offline   Reply With Quote
Old 07-21-2008, 09:06 PM   #8
Electrician
Why does it need to be exactly 2" ?
Old 07-21-2008, 09:12 PM   #9
No, we are not fishing - at least not most of it. For the most part the plaster and lath have been removed and we used a lot holes from the original wiring. The catch is that the original studs are true 2" x 3". This would have to fall into one of those great learning moments - a 3" stud (even a true 3") does not really give you proper wire cover. I, and my inspector, like to keep things neat, so if I can find a 2" wide self nailing plate it will be compliant and neat. Otherwise I think I could reasonably talk to him about using a 3" wide self nailing plate - assuming the teeth are in the middel and center it on the stud. Live and learn.
Old 07-21-2008, 09:27 PM   #10
Registered User
Termite's Avatar
The inspector shouldn't mind if you use a bigger nailguard than you need. This is very common, especially in plumbing. I'd never think twice about letting you drill a mounting hole to facilitate attachment if the available plates didn't have teeth mounted in a way that would work for your required placement. I'd suggest the bigger plates to him, with a nail hole drilled if necessary, and I bet he'll be ok with it.
Old 07-21-2008, 09:31 PM   #11
Electrician
Why dont you just fir the wall out to keep your 1 1/4 set back...
Old 07-21-2008, 09:34 PM   #12
Electrician
Would you really say anything about an 1 1/2 nail plate installed on a 2" stud with only 1/4" exposed material on either side? Assuming the nail plate was centered of course.
Old 07-21-2008, 09:36 PM   #13
I thought about furring out the studs but it really seemed like it would quickly become a very heart breaking exercise that would compound itself throughout this very large house. In many cases the wall trim, window trim and door casing have been left in place - furring out would require all that to be removed in order to maintain the detail look that the project calls for.
Old 07-21-2008, 10:34 PM   #14
Registered User
Termite's Avatar
Absolutely, without hesitation. 1/4" is plenty of meat for a sheetrock screw to shoot into and possibly catch a wire.
Old 07-22-2008, 07:14 AM   #15
Might have found 2" nail plates
Thank you for your help. The comment about Boca plates led me to a search and eventually I found this site. Looks like a 16 gauge 2"x5" plate is available.
http://www.metalproducts.com/plumbelec/safetyplates.htm
buying a nail gun with compressor Dave777 Tools 9 11-27-2011 11:37 PM
Nail Gun Plastic Nail Casing frustrations smark General DIY Discussions 6 07-07-2008 08:10 PM
Best Practices for Framing Nail size jms5883 Remodeling 7 01-31-2008 11:37 AM
Using nail gun on deck fence? darsunt Carpentry 1 05-01-2007 08:11 AM
Nail Gun and Compressor - Help! MelindaA Carpentry 7 08-15-2006 08:17 AM
