N00b Question - Cabinet Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 11:47 AM   #1
n00b question - cabinet lighting
Hey all-
Been doing woodworking off and on for a while, but not so much on the electrical.
I am currently building an entertainment center, 4 pieces. Main unit, two shelf units, and a "bridge" display section that goes between the two pier shelf units. The upper part of each is disguised by a trim panel in the upper 1/4 of the top shelf/box area.
I would like to wire them all with lights, but not sure how to go about it. The idea was a CFL in each "box", all wired down to a rocker switch that goes to a switched outlet. Alternatively I can just wire them to a plug that goes to the outlet.
I tried google searching for wiring CFL's, and all I got were a bunch of marijuana growing forums/plans.
Anyone have any tips/pointers/how tos/ or even look here you idiot?
Thanks!
John
JohnWP is offline   Reply With Quote
Old 01-18-2011, 06:31 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,104
There are many options available,
CFLs are usually bulky,
Will they fit in ?
This is a good place to use LEDS.
Small, compact, low in profile, low heat.
Try using some white LEDs,
Powered by a low voltage plug pack.
LED cabinet lights is a good place to start.
Originally Posted by JohnWP View Post
Hey all-
Thanks!
John
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
JohnWP (01-18-2011)
Old 01-18-2011, 10:09 PM   #3
Will they fit in ?
Hrm. Haven't looked at LED's. I'll have way enough room for the CFL's, but if the LED units are pretty much plug and play, then I can also unplug them later if I need to take the unit down.
John
Old 01-18-2011, 11:18 PM   #4
http://wwhardware.com/catalog.cfm?Gr...logen%20Lights
I think I will probably go this route. Not going to spend $500 on 5 LED lights for this.
John
Old 01-18-2011, 11:46 PM   #5
I have seen battery operated led cabinet lights,
at cheap hardware chains, also at discount stores.
there cheap as .
Search around you will find them.
You can eaisily convert them to plug pack powered.
John
Under cabinet lighting (Valence lighting) FredS Electrical 4 05-15-2010 11:18 PM
Kitchen cabinet lighting options... bcbud3 Electrical 9 04-30-2010 11:03 AM
under cabinet lighting 83trekker Electrical 7 01-11-2010 08:08 AM
Low Voltage Cabinet Lighting Recommendations BigJimmy Electrical 2 01-20-2008 02:01 PM
