Mystery Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2010, 07:05 PM   #1
sweaty
Rewards Points: 276
Mystery Receptacle
In my in-laws' house, there is a receptacle in the basement that would not work. I plugged in my tester and it said there was an open neutral. I opened it up and there was a loose neutral wire. After connecting it, there is no response at all from the tester. I replaced the receptacle with the same result. I've replaced over 100 of these things, so I know how to do it right.
This receptacle is on the same circuit as the outside one (which does not work) and a GFCI receptacle in the basement bathroom (which works). Any ideas?
sweaty is offline   Reply With Quote
Old 01-01-2010, 07:08 PM   #2
Go back to the last working receptacle and check your connections there.
Paelectrican is offline   Reply With Quote
Old 01-01-2010, 08:36 PM   #3
dSilanskas's Avatar
Is there a GFCI by the electrical panel? It might be fed from a GFCI
dSilanskas is offline   Reply With Quote
Isolated Ground Receptacle Bocolo Electrical 40 01-23-2012 02:44 PM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 09:52 PM
Receptacle Rating question Ultrarunner2017 Electrical 19 12-20-2008 06:20 PM
Receptacle Rating question Ultrarunner2017 Electrical 5 12-18-2008 05:36 PM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 09:28 AM
