Mystery Lights On Roof - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2012, 10:53 PM   #1
Rewards Points: 2,072
mystery lights on roof
My new house has a double set of outdoor lights on a front corner and also a corner in the back. Many neighbors have these.
What are they?
I still haven't figured out all the switches. Many bulbs in the house were burned out and I've replaced them and I think these may be burned out cause I never see them come on.
Could they be motion lights and if they are do motion lights have a switch. I took one out today to take to HD and match up with a new one before I invest in 4.
Then it rained and I hope rain didn't get into the empty socket, but I figured since they're outside they're probably moisture proof ?
Startingover is offline   Reply With Quote
Old 06-05-2012, 11:17 PM   #2
Rewards Points: 13,260
Post a picture, if there motion lights there has to be some sort sencer near the light.
Startingover (06-06-2012)
Old 06-05-2012, 11:19 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,866
What are they?
Sorry, crystal ball in the shop.
Can't tell what they are from here. The picture you posted is far too faded.
Old 06-06-2012, 08:06 AM   #4
speedy, thanks for starting my day with a smile.
Ok, photos coming right up.
The Following User Says Thank You to Startingover For This Useful Post:
Speedy Petey (06-06-2012)
Old 06-09-2012, 10:05 PM   #5
Ha. Discovered a light switch in the garage that operates the front flood lights. Then looked for a switch for the back flood lights and found that one in the living room.
Eventually I'll have these fixtures replaced with motion lights.
Old 10-15-2012, 05:59 PM   #6
I just had to come back and say I LOVE these flood lights on the corners of my house. They light up both sides and front and back.
When I get home after dark I'm always afraid someone is hiding in my yard behind a shrub. I turn on ALL the lights and peek out and I feel so much safer.
Old 10-15-2012, 06:25 PM   #7
Master Electrician
Buy a gun. It's cheaper than using the electricity and a much better deterrent.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 10-15-2012, 08:02 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,100
What are they?
Could be
1 - No power, ( not switched on )
2 - Faulty lamps or lamp base.
3 - Faulty motion sensor.
Start by replacing the lamps.
Then check for power at base if not working (tester).
dmxtothemax is offline   Reply With Quote
Old 10-15-2012, 08:07 PM   #9
Originally Posted by dmxtothemax View Post
Could be
See posts #5 & #6.
Old 10-15-2012, 08:11 PM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
If you want to hit your target, you need good lighting!!
The Following User Says Thank You to jbfan For This Useful Post:
Missouri Bound (10-16-2012)
Old 10-15-2012, 08:17 PM   #11
Rewards Points: 506
Send a message via AIM to theatretch85
Not if you have a shotgun, just aim in the general direction and fire; oh and hope you live out in the country...
theatretch85 is offline   Reply With Quote
Old 10-15-2012, 08:25 PM   #12
Rewards Points: 258
Night vision sight then the target doesn't know to run.
redman88 is offline   Reply With Quote
Old 10-16-2012, 07:43 PM   #13
Rewards Points: 266
Damn, I thought you found the lights for my two mystery switches
ionized is offline   Reply With Quote
Old 10-17-2012, 12:23 AM   #14
Common Sense Common Guy
Rewards Points: 161
I have these on my home too, they're security lights. Mine have 3-way switches on both floors of the house for the sets on the corners. As to their resiliency, I have a set of spotlight bulbs that are in mine that have been there since the house was built in the early 1990's. Hailstones broke the front glass in the bulbs -- I found it lying on the sidewalk one morning... but the bulbs still work to this day.
flasherz is offline   Reply With Quote
Old 10-19-2012, 11:17 AM   #15
you guys are a riot.
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 10:00 PM
Are you ready for SNOW & ICE ? Roofmaster417 Roofing/Siding 15 10-09-2011 10:25 AM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 07:11 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
