Old 02-04-2012, 10:55 PM   #1
Mystery Light Switch
In our mudroom is a double gang box with two switches. They are both 3-way switches. One controls the light in the room (and another switch in the garage controls this same light) but the other one has been a mystery ever since we've owned the home. The mystery switch is bigger than regular 3-way switch and says "SPEC GRADE" on it.
In the garage switch box (which has the second switch for the mudroom and a garage switch) there is another switch just like the mystery one that controls the garage lights. This is also 3-way because another switch by the outside door turns these same lights on.
So what gives? What is a Spec Grade switch? Also, what is the easiest way for me trace the mystery switch? What may it likely control? The house was built in the late 80s. Thanks!
smokey847 is offline   Reply With Quote
Old 02-04-2012, 11:26 PM   #2
Licensed electrician
Spec Grade is a higher quality of device than the bulk bin versions.
Do you have outside lights that the switch may control?
Old 02-04-2012, 11:31 PM   #3
I have looked and nothing comes on when I flip the switch. It is also 3-way so it leads me to believe that it MAY control the garage light (makes sense) and is not connected properly. Any other ideas?
Old 02-04-2012, 11:44 PM   #4
SOLVED: Just redid the connections and it does, in fact, control a set of outdoor floodlights. Thanks!
two switch ceiling fan/ light question ifthenelsenull Electrical 4 12-29-2011 04:23 PM
Wiring a New Light Switch but Problems nlsnrn Electrical 8 08-31-2011 04:36 PM
Need to add a light near switch in 3-way setup.... prosper50 Electrical 5 03-19-2011 10:19 PM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 50 09-01-2009 09:20 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
