#1 |
Is my wiring ok?
so i'm trying to wire up a new electrical outlet for a tv. busted up the walls and drilled holes through the studs. then i knocked out a corner of the jbox. i wired the new romex to sides. the white to the silver screw, the black to the brass screw, and the ground attached by a cap. i believe the romex is fine going through the insulation right? i'm getting 120v. anyone see anything i should be aware of?
the outlet i wired up to https://www.box.com/s/8eiy05j7c4uugvl6qp9l wiring through the studs and insulation https://www.box.com/s/vlxtndrbj0ylxn17j8me |
#2 |
DIY Enthusiast
Is my wiring ok?
I would have pigtailed 2 of the wires to avoid using the back stab on the receptacle.
#3 |
Is my wiring ok? |
#4 | |
DIY Enthusiast
Is my wiring ok?Quote:
http://www.usahardware.com/inet/shop...let/62800b.htm To protect the wires. |
#5 | |
The outer sheathing of your new romex is extending too far into the box. It is good practice to seat all screws, even if they are un-used (lower silver screw) |
#6 |
Is my wiring ok?
Ok I'll fix the sheath. The screws were like that when I opened it. I'll seat them. Thanks.
#7 |
Is my wiring ok?
Here's the shot with the seated screws, and you can see the lower right corner where my new romex is coming in. I cut some of the sheathing and then pulled it back to minimize the amount that is in the box.
https://www.box.com/s/asp8p1sd67ot0se7r0zr |
| Display Modes | |
| Attic wiring - ceiling lighting uses 14/2 cable without ground | darlingm | Electrical | 3 | 11-29-2011 10:01 AM |
| Backyard wiring questions | MikeInDetroit | Electrical | 1 | 11-02-2011 10:46 AM |
| Cloth Wiring - Replace? | JessicaGus | Electrical | 9 | 09-23-2009 07:45 PM |
| Replacing wiring in middle of run, ungrounded lighting circuit | alexz | Electrical | 3 | 07-05-2007 09:53 PM |
| Knob & Tube wiring - How concerned should we be? | hotdiggitydog | Electrical | 6 | 04-11-2006 08:52 PM |
