-   -   Is my wiring ok? (http://www.diychatroom.com/f18/my-wiring-ok-168930/)
allivant 01-12-2013 03:48 PM
Is my wiring ok?
so i'm trying to wire up a new electrical outlet for a tv. busted up the walls and drilled holes through the studs. then i knocked out a corner of the jbox. i wired the new romex to sides. the white to the silver screw, the black to the brass screw, and the ground attached by a cap. i believe the romex is fine going through the insulation right? i'm getting 120v. anyone see anything i should be aware of?
the outlet i wired up to
https://www.box.com/s/8eiy05j7c4uugvl6qp9l
wiring through the studs and insulation
https://www.box.com/s/vlxtndrbj0ylxn17j8me
sublime2 01-12-2013 03:54 PM
I would have pigtailed 2 of the wires to avoid using the back stab on the receptacle.
allivant 01-12-2013 03:57 PM
So everything else looks ok? I want to make sure before I move on and repair the drywall.
sublime2 01-12-2013 04:01 PM
Only thing I would suggest is a plate,
http://www.usahardware.com/inet/shop...let/62800b.htm
To protect the wires.
Oso954 01-12-2013 04:13 PM
Your photo doesn't show it. Could be a big no-no.
The outer sheathing of your new romex is extending too far into the box.
It is good practice to seat all screws, even if they are un-used (lower silver screw)
allivant 01-12-2013 04:15 PM
Ok I'll fix the sheath. The screws were like that when I opened it. I'll seat them. Thanks.
allivant 01-12-2013 04:27 PM
Here's the shot with the seated screws, and you can see the lower right corner where my new romex is coming in. I cut some of the sheathing and then pulled it back to minimize the amount that is in the box.
https://www.box.com/s/asp8p1sd67ot0se7r0zr
