My Water Heater (Whirlpool 50 Gallon Model #EE2H50RD045V) Will Not Heat Water - Electrical - DIY Chatroom Home Improvement Forum
Old 02-01-2009, 10:13 PM   #1
My water heater (Whirlpool 50 gallon model #EE2H50RD045V) will not heat water
My water heater (Whirlpool 50 gallon model #EE2H50RD045V) will not heat water, The green light stays on with no errors but you can hear the relays clicking every now and then. I watched my electric meter when I first turned the breaker on and you could see it speed up but after a couple of seconds it would slow back down indicating the heater was not working. I watched it a little longer and it would speed up for a couple of seconds and then slow back down. Could this be an element or the circuit board? I am leaning to the circuit board by the way it acts.
FastXD is offline   Reply With Quote
Old 02-01-2009, 11:19 PM   #2
Rewards Points: 862
This is 220V or 220/115 on a double-pole breaker, right?
Make sure you have the correct voltage at the water heater.
I would also suspect the electronics, since you say you hear relays clicking every couple minutes and see power usage briefly, but I would always want to make sure I've got the proper power first.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 02-01-2009, 11:55 PM   #3
Cow
Double check power with a meter first. After that call the tech support number on the front of the water heater. You probably have a bad board. I have a Whirlpool also, and had to put a board into it a year or two after I bought it, it had the same symtoms you describe. Tech support sent it to me free of charge.
Cow is offline   Reply With Quote
Old 02-02-2009, 05:01 AM   #4
Electrical Contractor
kbsparky's Avatar
Circuit boards in electric water heaters now? Sheesh, take something simple and make it complicated ....
Old 02-02-2009, 07:04 AM   #5
Rewards Points: 862
Exactly my thoughts! Why does anyone need electronics on a hot water heater? They have been working fine with old fashioned thermostats.
It's probably some "energy-saving" system.
With all the electronics in appliances today, I would seriously consider a whole-house surge suppressor. My C&H panel is made to accept one.
FW
Old 02-02-2009, 07:45 AM   #6
Whatamess
Toilets maybe next.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 02-02-2009, 09:35 AM   #7
Rewards Points: 862
Originally Posted by TazinCR View Post
Toilets maybe next.
I think they're already there<g>
There are toilets with heated seats. Probably use an electronic control.
Also, there are variable fill/flush toilets that allow for a short flush or a normal one; again, most likely electronics to control the valve.
I'm waiting for the electronic electrician's plier. It will tell you whether or not you have live wires just as you are about to cut them! Now, that might be a useful invention<g>
FW
Old 02-02-2009, 09:49 AM   #8
FW
Close enough?
http://www.amazon.com/GB-GST-224-Sta.../dp/B000BVZBF2
jerryh3 is offline   Reply With Quote
Old 02-03-2009, 10:58 AM   #9
Rewards Points: 862
FastXD;
I would seriously consider installing a whole-house surge protection device to protect the electronics on the water heater, and other appliances.
We have a thread going here at:Whole House Surge Protection? if you want to get some input.
FW
Water Heater tsmith Plumbing 10 12-01-2008 07:24 PM
Tankless Hot Water Heater - One Fauset Does Not Have Hot Water? vsheetz Plumbing 1 10-29-2008 12:18 AM
Water heater "leak"? TCinKC Plumbing 1 09-25-2008 01:01 PM
"sticky" gas water heater thermostat homer12 HVAC 7 01-22-2008 07:08 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
