My Vacuum Acts Like A Switch To Turn The Lights On - Electrical - DIY Chatroom Home Improvement Forum
Old 07-18-2011, 01:41 PM   #1
YPY
My vacuum acts like a switch to turn the lights on
When i plug my vacuum in the bedroom and i try to turn it on, instead of the vacuum to turn on the light on the room turns on and the vacuum reemains off. It seems the vacuum switch becomes the swittch for the ligh. any ideas why?
YPY is offline   Reply With Quote
Old 07-18-2011, 02:04 PM   #2
I=E/R
a7ecorsair's Avatar
The light that comes on, is it plugged into a wall receptacle or is it a ceiling light?
a7ecorsair is offline   Reply With Quote
Old 07-18-2011, 02:04 PM   #3
Electrical Contractor
Loose nuetral at the receptacle. Either at the one that your useing or a receptacle up stream.
hpp58 is offline   Reply With Quote
Old 07-18-2011, 05:08 PM   #4
Rewards Points: 1,494
Did you do some wiring changes or additions of your own in the bedroom or nearby recently? A wiring mistake could cause this problem.
AllanJ is online now   Reply With Quote
Old 07-18-2011, 05:29 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,166
does the light come on at full brightness ?
Or is it dull ?
I would also think there is a bad connecttion somewhere,
dmxtothemax is online now   Reply With Quote
Old 07-18-2011, 06:11 PM   #6
I=E/R
a7ecorsair's Avatar
Or this could be BS. Let's see if the OP comes back with a followup.
Old 07-18-2011, 07:08 PM   #7
joed's Avatar
Rewards Points: 12,362
Most common cause of this issue is someone trying to install a new receptacle below a light switch that is a switch loop.
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 12:31 PM
two lights two sources one switch bgbur98 Electrical 1 01-30-2011 07:48 PM
2 lights 1 switch lymantuttle Electrical 10 01-04-2010 05:49 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
1 switch, 3 lights? help? bexnfx Electrical 5 09-12-2005 02:17 PM
