My TVs Stopped Working. Is This A Problem With My Electricity? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 12:03 AM   #1
My TVs stopped working. Is this a problem with my electricity?
Last week my plasma tv in my living room went dead, it was working fine the night before, and next day it just wouldn't power on. I tried plugging it in a different place but it still didn't power on. Everything else connected like the dvd and cable box did work though.
There isn't any bad weather here were i live, no rain or lightnings, no power outtage.
Today my second tv in my bedroom suddenly went into the static image (like in the movie The Ring which it scared me) and then it turned off by it self. I tried powering it back on but it didn't work anymore!. What the heck? I tried to plug it in another outlet and that didn't work either. And same thing the rest of the stuff connected seem to work.
So any ideas of what could be causing my TVs to die? Now I'm afraid that my third and last tv will die too!. Everything else in the house like microwave, fridge, stereos, clocks, etc.. seem to be working fine though.
It's weird that both TVs went dead.. what should i do? Is this a sign that the end of the world is near?
Thanks in advance
LynniieRockz is offline   Reply With Quote
Old 02-27-2012, 12:42 AM   #2
just a tool guy
mickey cassiba's Avatar
Have you paid the cable bill?
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
Old 02-27-2012, 12:44 AM   #3
Yes, it's the TVs that wont power on. Only that. The rest of the stuff connected does work.
Old 02-27-2012, 12:44 AM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Not paying the cable bill don't cause a tv to stop powering on. LOL
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
LynniieRockz (02-27-2012)
Old 02-27-2012, 12:47 AM   #5
rrolleston's Avatar
I would have the outlet checked out and if plugged into something after the outlet I would also check that out. A lose connection causing a voltage drop could cause the tv to overheat and stop working.
Old 02-27-2012, 12:59 AM   #6
But my two TV's in different rooms stopped working in the same week, and if i plug something were the TVs were plugged it does work. Someone told me it could be a leakage current?
Old 02-27-2012, 01:05 AM   #7
rrolleston's Avatar
Could be they are on the same circuit or one leg of your power or both have a voltage drop. A lose hot or neutral wire. Anything electronic will not like this. I would start with having your electrical system checked.
Old 02-27-2012, 05:54 AM   #8
Signal Guy's Avatar
Check your voltage at the outlets to maKe sure it is not running high.
Also check for a bad neutral connection in your electric service panel.
If neither pan out, then perhaps its just a bad coincidence. maybe you have a surge. are both sets hooked to surge protectors? if not, they should be.
the ones I use to recommend had connections for the cable wire to plug in through the surge protector.
Signal Guy is offline   Reply With Quote
The Following User Says Thank You to Signal Guy For This Useful Post:
LynniieRockz (02-28-2012)
Old 02-27-2012, 07:22 AM   #9
Rewards Points: 1,448
Is the TV completely dead, or does it just not do some things like pick up any stations?
Would it work if you connected up a DVD player a different way, for example if you used the blue and green jacks try putting the green cable into the yellow jacks at both the TV and the DVD player. (For just a few minutes while testing.).
Old 02-27-2012, 08:01 AM   #10
What brand of TV is it? Samsung had trouble with capacitors on the power supply. I had this happen to my TV and had to replace six capacitors.
M Engineer is offline   Reply With Quote
Old 02-27-2012, 08:08 AM   #11
Signal Guy's Avatar
Not just Samsung. They all run the caps right up to their thermal limits.
Old 02-27-2012, 08:44 AM   #12
joed's Avatar
Rewards Points: 12,008
Could be a power issue taking out the TVs. If you have a loose neutral on your main service then then the voltage could spiking high and taking out your TVs. Are you noticing lights going brighter within your house?
The Following User Says Thank You to joed For This Useful Post:
Old 02-27-2012, 09:50 AM   #13
Rewards Points: 13,300
Both of my Visios dead within 2 years.
Both had cap problums and the repair places wanted $400.00 to repair, the company knows there's a problum judgiing by the number of complaints I see posted on line.
Replaced them with Sonys and never had another problum.
I did also hook up the cable, power and phone line to a surge protector I bought at Wal Mart just to try and play it safe.
Old 02-27-2012, 09:59 AM   #14
liscenced electrician
Rewards Points: 538
Could be a lose neutral causing your voltage to be all over the place
jimmy21 is offline   Reply With Quote
The Following User Says Thank You to jimmy21 For This Useful Post:
Old 02-27-2012, 10:41 AM   #15
Are they both Plasmas? Does either make a series of clicks when it tries to power on? I have a 42" plasma that would not power on and replacing the A-board and power supply board did the trick. Many of these boards are compatible with multiple brands. (Kinda like GM parts,YAY for Government Motors!) Anyways, if you bought a bargain TV, chances are you got what you paid for just as I did. It cost me about about $200 to fix myself so depending on how old they are you may be better off just buying new. Or better yet just go on craigslist and get a free CRT that will last forever. Regardless, the fact that two of your TV's went on the fritz at the same time sounds like the MAIN issue is not within the TV. I suggest doing what the electricians recommend before addressing the tubes.
MisterSteve is offline   Reply With Quote
The Following User Says Thank You to MisterSteve For This Useful Post:
What would cause the electricity in only one room to suddenly stop working? Iron Petunia Electrical 7 12-22-2011 05:54 PM
Coaxial Jack STOPPED working? JayNYOne Electrical 4 12-11-2011 11:20 AM
Powermate stopped making electricity (field issue?) desmo907 Electrical 6 11-17-2011 02:20 AM
Shower Lighting and fan stopped working (separate fixtures on same circuit) IndyNotHandy Electrical 15 03-15-2011 10:39 AM
Rheem furnace stopped working kgsolomon1 HVAC 1 02-09-2008 07:51 PM
