Old 04-02-2009, 12:54 PM   #1
Is my room pre-wired for a ceiling fan?
I am definitely a novice when it comes to electrical work, and the extend of my electrical experience is pretty...I was able to replace to chandeleirs in my house, and that's it.
I'm getting ready to install a ceiling fan in my childs nursery (will be born in July), and i'm not sure how big this job will be because i don't know if my room is prewired.
I live in Reston, VA, and we bought our townhouse in June...Off the top of my head, i want to say my townhouse is about 15 years old. In the room that i'm working with, i can't really access the ceiling through the attick because the attic has a floor too it, and is not beams. I suppose i could try and pry up boards to get to the rooms ceiling, but that sounds like a complete mess. The ceiling in the room is just a drywall ceiling and there is no indication that there is wiring above the drywall, but there is a switchbox right near the light switch in the room that i have no idea what it is. it's on the same wall and only abotu one foot over at the same height...Is there a chance that this switchbox/plate is for wiring in the ceiling to install a fan or is this more likely a box for a sound system, etc. I have no idea what its for???
The last think i want to do is get into putting holes in my ceiling to run a wire to the outlet in the room that is connected to the light switch, but i might have to. Any suggestions how i should tackle this project???
cfrederick02 is offline   Reply With Quote
Old 04-02-2009, 02:08 PM   #2
Remodeling Contractor
No it is not. The lighting box would be exposed if it were. The switch most likely controls one half of the outlet for a lamp.
More On This Topic
Using full sheets of drywall--also called sheetrock--is recommended whenever possible, but designing a project perfectly around the standard size of a sheet of drywall isn't that easy. So measuring when installing drywall and cutting the sheet to your... Read More »
I'm doing a demonstration for Expert Village Painting 101. Okay down here is a little different than the other room we looked at. There was really no taping necessary because here we are going to paint the whole room, the whole walls and ceilings. The... Read More »
Right now I started a project. When I first started it had all the ceiling, the whole ceiling was taking down. So I had to put tracks so I can put the new ceiling up. I'm trying to sound proof it so when they record down here. I build the booth so when... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. Probably eventually I would be putting in other smaller rooms in her but in the mean time I want it to go very quickly to put a ceiling in this room which would be a floor of the... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about preparing for drywall. Now that we've finished insulating our garage, we can go ahead and get ready for putting drywall up. You want to make sure that any... Read More »
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Plaster ceiling and drywall desrtrat Drywall 13 10-08-2008 08:20 AM
Ceiling bits are falling off!! infection0 Building & Construction 4 09-15-2008 06:00 AM
Wall to ceiling fw2007 Electrical 4 03-31-2008 07:18 PM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-25-2006 12:23 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
