My Plan For Bsmnt Has Panel Packed - Should I Upgrade? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-25-2013, 09:43 PM   #16
Rewards Points: 83
Well, while I'm at it...
I ran a 6 gauge copper feed to my garage, another to my utility room, and one to the side of the house. I put 50A breakers on them. One comes from my original 100A panel, the other two from my new panel, which will be underutilized otherwise.
danielrg is offline   Reply With Quote
Old 06-25-2013, 09:59 PM   #17
Resi EC
Rewards Points: 252
How was the second panel fed?
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Old 06-28-2013, 03:55 PM   #18
Rewards Points: 83
Utility (200A) ----> Meter --> Main Panel (outside house)
- Main panel was 100A, upgraded to 200A. Fortunately the feed wires already supported 200A so utility didn't have to pull new.
Main Panel 100A Breaker #1 --> existing Basement panel
Main Panel 100A Breaker #2 --> NEW basement panel
Electrician pulled some big fat aluminum wire - I don't remember the size - from the main panel outside house to this new load center.
Old 06-29-2013, 10:27 PM   #19
Rewards Points: 1,192
Originally Posted by danielrg View Post
I installed another 100 AMP panel. Best thing I ever did. I don't see how I could have fit everything in the one panel.
Because of the space, I was also able to run a subpanel to my utility room, garage, and a feed to my future shed location.
So in my opinion, the upgrade was well worth it.
You are streching you main breaker capacity by adding more panels. Bad move.
bobelectric is offline   Reply With Quote
Old 07-01-2013, 09:48 PM   #20
Rewards Points: 83
Originally Posted by bobelectric View Post
You are stretching you main breaker capacity by adding more panels. Bad move.
Which panels are you referring to? The (2) 100A basement panels?
Or the 50A sub-panels (garage/utility/shed) off the 100A panels?
How am I "stretching" my main breaker capacity? My main is 200A, upgraded from 100A. Then I have two 100A breakers, one to each panel.
Maybe I just don't understand. What does it mean to "stretch" a breaker's capacity? I do see from my post that I didn't really say explicitly that I also upgraded my service from 100A to 200A and then added the 2nd 100A panel.
Old 07-01-2013, 10:12 PM   #21
Rewards Points: 83
In case anyone is confused on what I did - I copied this out of my basement planning drawings:
I don't really plan to put much on my subpanels. Right now they are in but empty - I put in copper 6/3 so I could do 50A to any of them, but I may put them on 30A breakers. Mostly they are there for convenience since the basement walls are going to get closed up and I want to be able to add circuits to these areas later.
Main Panel Upgrade Invisible-Man Electrical 21 08-23-2011 03:24 AM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
garage panel upgrade Tradesman14 Electrical 3 09-29-2009 11:20 AM
Upgrade Service Panel - Do I need a new meter? El Kati Electrical 6 08-11-2008 07:35 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
