My Panel Is Detaching From House - Electrical - DIY Chatroom Home Improvement Forum
Old 07-05-2013, 02:11 AM   #1
Rewards Points: 892
My panel is detaching from house
Can someone give me some guidance on this job. My breaker panel is coming off or basically, has come away from my house. It was attached with screws into the wod sheathing.
Shouldn't there be a piece of sheet metal to protect the wood from the elements?
Anyhow, I want to reattach it but I can't take off a side panel to access two of the bolts. The electric company has a lock on it. So I can't take the bolts out to fix the panel.
Is this a job for an electrician. Do they have special keys to remove that lock?
I haven't called an electrician yet..
Daugela is offline   Reply With Quote
Old 07-05-2013, 06:43 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
In my area, 1 of 2 things would happen.
1) An electrician would cut the seal, make repair, contact POCO to reseal the meter.
2) The HO would pull a permit, contact the POCO and get a work request to pull the meter, the POCO would come pull the meter, repairs would be made, repairs would be inspected, and the POCO would come back and re-install the meter and seal.
I would call an electrician.
wirenut1110 is offline   Reply With Quote
Old 07-05-2013, 07:54 AM   #3
Rewards Points: 13,300
Part of the reason it failed is because someone spaced that box out away from the wall which would allow water to get in behind the siding and rot the spacers, screws, and sheathing, no Z molding was used over the top of the box to deflect the water away from the top of the box, and it looks like the J molding was installed wrong.
Old 07-05-2013, 08:27 AM   #4
MarginallyQualified
Rewards Points: 2,464
I'd call whoever did that lousy siding job and tell HIM to call the electrician
...and then to fix the vinyly work as well
Old 07-05-2013, 08:51 AM   #5
Rewards Points: 6,652
If I had to make a fair guess, that siding appears to have been there going on around 10 maybe 15 years.
Old 07-05-2013, 10:31 AM   #6
Rewards Points: 892
Gregzoll, you won the prize.
House was built in 1993. Assuming that's when the vinyl went up. Bought last month. Pretty much got a screaming deal - fixer upper.
I will call an electrician. Figured so. Wonder what it will cost me?
I will also be tearing down the vinyl and redoing the house.
Looking for a quality siding. I live in Phoenix. We reached 120 degrees the other day. My house is specifically in a rural farming area so there's alot of trees, but none on my place. No shade.
Everyone here typically puts stucco on their homes to defeat the heat. This house is 2x6 construction with cellulose walls. Really efficient. I really like the traditional look of siding. Would cement board hold up in the heat?
Old 07-05-2013, 11:03 AM   #7
MarginallyQualified
The first visit by the electrician to open the box and then install the 3 or 4 new screws required to stabilize ... will cost a min trip fee or maybe even nothing at all if he is sure he'll be back to do the rest of the rest of the work you'll need/want done after or as the vinyl is replaced.
Old 07-05-2013, 11:32 AM   #8
Licensed electrician
Rewards Points: 1,294
When you redo the siding look at installing something like the MM10, but larger from Arlington. They can be grouped to get the size you need.
aifittings.com
Old 07-05-2013, 12:00 PM   #9
Rewards Points: 892
aifittings.com
I like that. But could the job not be done without replacing the siding? Wasn't planning that for a while.
I guess I would cut the vinyl around it and make shift some flashing for the guy to put the box back on?
Old 07-05-2013, 12:42 PM   #10
You might be able to slide the MMs behind the box and use long screws to secure to the structure. Some siding work might be required.
Sub Panel over 10g-2 Help Needed hamblinh Electrical 30 01-18-2013 08:46 PM
Wiring a sub panel? Possibly More. Feltope Electrical 4 06-08-2012 05:00 PM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
