Is It My Outlet Or My Light Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2011, 07:33 PM   #1
Is it my outlet or my light switch?
Hey all, first time here. 25 year old first time home owner, with no electrical knowledge... I'm pretty crafty with most things, more of a tech guy, but I'm learning a lot of DIY stuff since I got married and bought my home.
Anyhow, we believed our garbage disposal was broken since it would only turn on occasionally... it is an outlet type, not a hardwire type. So we bought a new garbage disposal and installed it, only to find it did the same thing. I then tested the outlet under the sink for any problems by hooking the disposal up to another outlet with an extension cord, and it works fine (Yeah, shoulda tested that first, I know). I'm fine with the new disposal cause its like 3 times more powerful, so I wanna keep it anyway.
Getting to the point... now I'm not sure if the issue is the wall switch for the disposal or the actual outlet. I have zero electrical knowledge, is there an easy way to tell?
brodtaylor is offline   Reply With Quote
Old 01-28-2011, 07:56 PM   #2
Rewards Points: 506
Easy is a relative term. Will require disassembly of the switch and/or the receptacle and testing each device, perhaps with a meter. There is a good possibility it is a loosely connected conductor.
Zero electrical experience could be troublesome or dangerous. Do you know which circuit breaker in your panel serves that circuit? Make certain to disconnect the power at the panel before opening up any switches or receptacles. Once you are certain which circuit is the correct one, and it is disconnected, then a number of folks here can walk you through a troubleshooting exercise.
jlmran is offline   Reply With Quote
Old 01-28-2011, 08:22 PM   #3
Yeah, it is clearly labeled in the panel. I'm pretty good at researching and figuring things out, but had no clue where to even begin on this one. I can probably do some research online and see how difficult this is and if it is beyond me.
Thanks!
Old 01-28-2011, 08:27 PM   #4
Rewards Points: 1,512
A loose connection could be at either the switch or the outlet, no way to predict which. (Or the loose connection could be somewhere else.)
You could use a voltmeter to help narrow down on the location of a problem before actually removing a switch or receptacle from its box.
Old 01-29-2011, 12:55 AM   #5
Scared Electrician
Saturday Cowboy's Avatar
Can't tell you the number of times that has zapped me. ALWAYS verify that the circuit is off by testing. Labeling is not a good way to tell. When we electricians label panels and something is left, we guess, circuits may have moved or been modified, or it just maybe accurate- you just never can tell.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 01-29-2011, 07:29 AM   #6
Rewards Points: 506
Thanks!
Do you own or have access to a voltmeter?
Old 01-29-2011, 07:32 AM   #7
I could borrow one, but I could probably use one anyway, so I'll purchase one.
Old 01-29-2011, 07:43 AM   #8
Rewards Points: 506
Voltmeter can be used to measure voltage and verify continuity. With the power off you can validate the screw tightness at the device's conductor connections.
Looking for loose connections is a very logical place to begin.
The Following User Says Thank You to jlmran For This Useful Post:
brodtaylor (01-29-2011)
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
adding outlet from light switch tad Electrical 17 06-05-2009 11:25 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
