My New Threadmill Cause One The Circuit Breaker To Trip A Lot - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2013, 06:29 PM   #1
Rewards Points: 93
my new threadmill cause one the circuit breaker to trip a lot
i just bought a threadmill and put it in one of my rooms. nothing in the room except one computer and the threadmill. why is the circuit breaker for that room overloaded and keeps tripping with just a threadmil and one computer. anything i can do about this?
dumbengineer is offline   Reply With Quote
Old 01-28-2013, 06:32 PM   #2
Rewards Points: 14,026
Read the directions, does it say something about having to have a 20 amp outlet or a dedicated circut?
Is this an old house?
Old 01-28-2013, 06:36 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
TREADmills are notoriously heavy draw loads. It is very typical for them to trip existing 15A circuit breakers.
Most likely you will need a new 20A circuit run to the location.
Speedy Petey is online now   Reply With Quote
Old 01-28-2013, 06:44 PM   #4
Rewards Points: 93
will single-outlter surge protector help with the trip?
also how do i check which outlet in my house has 20 amps?
Old 01-28-2013, 06:47 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,980
Surge protector? NOPE.
You know that breaker that you have to reset when it trips? It has the amperage listed on the handle. It will say either 15 or 20.
Look at the instructions and see what it says it needs.
ddawg16 is online now   Reply With Quote
Old 01-28-2013, 06:49 PM   #6
A surge protector is only to protect from incoming power spikes. Not going to fix the problum.
Going to have to check the breakers to see if there's a 20 amp and if it kills a breaker.
Old 01-28-2013, 06:52 PM   #7
Rewards Points: 93
the instruction says it's requiring a surge protector rated for 15 amps so i guess it only require 15 amps.. gonna check my circuit breaker which room/outlet has 20 amps.. tnx
Old 01-28-2013, 07:28 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,512
The circuit breaker is not big enough !
What else is on that circuit ?
Could be other things in other rooms !
dmxtothemax is offline   Reply With Quote
Old 01-28-2013, 07:51 PM   #9
Rewards Points: 216
I'm with Joe on this-- when I was installing my treadmill the instructions were quite clear --dedicated circuit.
It's on a dedicated 15A circuit in basement and no issues.
Good luck.
orange is offline   Reply With Quote
Old 01-28-2013, 11:26 PM   #10
Hhhmmm. If it was me having that problem it would be because the motor was trying to get my fat @#+ moving. A 50 amp breaker and three corn dogs and maybe a large diet soda is the only thing that might work. But thats me.
grizzzlle is offline   Reply With Quote
Turning on Lights trip another breaker RevJones Electrical 5 06-04-2012 11:36 PM
New wiring tripping breaker on another circuit? Kinggofg Electrical 11 04-26-2012 01:36 AM
circuit breaker doesn't trip harryevan Electrical 31 02-11-2011 08:27 PM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 02:44 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
