My New Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2012, 11:14 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,342
My New Panel
Here's the panel I just bot. It's the Siemens G3030B1100CU. So 100AMP/30 spaces/30circuits.
I like the copper bus and the fact that the ground bar is included. The Siemens breakers also seemed like they're decent quality.
What I don't like are the plastic tabs that the breakers clip into.
What do you think? Is it a keeper?
I'm swapping out a 12/24 GE panel that is will be re-purposed to the garage/shop.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 01-28-2012, 11:18 AM   #2
Julius793's Avatar
Well if you don't want it I'll take it.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-28-2012, 11:29 AM   #3
I have gas!
Lowes used to have a pretty good panel display. They have since done away with that. Had I known that it had plastic tabs for the breakers, I probably would have passed this one up.
Old 01-28-2012, 11:42 AM   #4
Sparky
Rewards Points: 510
almost every loadcenter out there uses a plastic support anymore, sadly.
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
plummen (01-29-2012)
Old 01-28-2012, 11:50 AM   #5
Electrical Contractor
kbsparky's Avatar
Is this your main panel?
-KB
Old 01-28-2012, 11:54 AM   #6
I have gas!
Yes it will be the main and only panel. Since I'm completely redoing the electrical, I've decided to just replace the current panel rather than add a sub.
Old 01-28-2012, 11:56 AM   #7
kbsparky's Avatar
Then your neutral and grounding wires can connect to both neutral bars. Be sure to sink down that green bonding screw as well.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Old 01-28-2012, 12:02 PM   #8
I have gas!
KB,it sounds like you have some experience with Siemens load centers. Did you ever come across one where a tab broke off rendering the space unusable? That's my biggest concern.
Old 01-28-2012, 12:06 PM   #9
jbfan's Avatar
Rewards Points: 386
I've never seen a broken tab.
All the tab is for is to keep the back of the breaker inline with the buss.
The Following User Says Thank You to jbfan For This Useful Post:
Old 01-28-2012, 01:42 PM   #10
Master Electrician
Rewards Points: 3,818
Use Siemens a lot. Never seen a broken tab or broken one myself.
brric is online now   Reply With Quote
Old 01-28-2012, 04:24 PM   #11
" Euro " electrician
frenchelectrican's Avatar
I have used few differnt modern panels and I have NOT ran into any broken plastique tabs the only time I ever see the broken plastique support tab is someone try to install wrong breaker that was it.
You will be fine with the 30 space panel.
Merci,
Marc
Old 01-29-2012, 09:41 AM   #12
I have gas!
Thanks guys, I'm going to keep it.
I went to Lowes to scour through some open boxes to see if all the brands are using the same cost cutting practices. For the most part, yes. The Square D homeline panels looks like they used even thinner plastic than Siemens. GE's panels do have a metal retainer clip so maybe it might be a slightly better panel.
The GE breakers, however, look like they've been kicked across the floor, kind of a poorly refurbished look, even the GE packaged AFCI's have that look to them.
I guess in the residential-load-center it's all about price so that drives a cheap build into the panels.
Old 01-29-2012, 10:29 AM   #13
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Anything is an improvement over the ge panel
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-29-2012, 10:44 AM   #14
Rewards Points: 264
plummen, Well if that's the case, I've got a used FPE panel that I might be able to interest you with.
a_lost_shadow is offline   Reply With Quote
Old 01-29-2012, 10:48 AM   #15
plummen's Avatar
Ive got plenty of them federal pacific panels i keep laying around for spare parts for emergency jobs
As far as newer panels go I personally rate the ge stuff down towards bottem of pile
Panel cleanup gdoucette Electrical 5 06-26-2010 02:01 PM
Sub Panel SoxFan Electrical 2 12-02-2008 10:16 AM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
