Old 03-10-2011, 08:17 AM   #1
My new light fixture doesn't work!
I installed a three-way light in my home and it worked for months. Then we noticed it didn't work anymore. I bought a new light fixture thinking it was the fixture itself - because when i turn on the switch, the hot wire has power, and when i turn it off, it doesn't, so wiring doesn't seem to be a problem, and the wiring hasn't changed since the last light, Now when I turn on the light with the new fixture installed, it makes the wires hot but the lights still don't come on. - I'm sure the wiring is correct, as I've installed other three ways in my home with absolutely no problems.
Any ideas?
BBhomerepair is offline   Reply With Quote
Old 03-10-2011, 09:03 AM   #2
Licensed electrician
Without a way to return the current to its source the fixture will not work. You need to check all the connections. Sounds like you have lost the neutral.
Old 03-10-2011, 09:30 AM   #3
If nothing has changed... It is likely as mentioned, a loose connection on neutral or you could check the switches to ensure they are functioning correctly, I've seen burnt out three-way's before. With a multimeter you can verify continuity between the common and each of the travelers depending on the switch. Do this with the switch removed.
You could check the neutral issue with a meter also... And I would physically look at the connections under all the wire nuts.
cschwehr is offline   Reply With Quote
Old 03-10-2011, 10:05 AM   #4
I'll check the neutral wires tonight. that may just be it. in fact i'm almost certain of it. Thanks again!
Ceiling fan light fixture doesn't work c4hfam Electrical 9 03-05-2011 02:01 PM
Issues hooking up new light fixture ddzc Electrical 6 11-29-2010 08:19 PM
Light fixture in ceiling fan won't work. Tested DIYself Electrical 7 11-28-2010 12:52 PM
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 10:26 PM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 09:43 PM
