-   -   My new light fixture doesn't work! (http://www.diychatroom.com/f18/my-new-light-fixture-doesnt-work-97896/)
BBhomerepair 03-10-2011 07:17 AM
I installed a three-way light in my home and it worked for months. Then we noticed it didn't work anymore. I bought a new light fixture thinking it was the fixture itself - because when i turn on the switch, the hot wire has power, and when i turn it off, it doesn't, so wiring doesn't seem to be a problem, and the wiring hasn't changed since the last light, Now when I turn on the light with the new fixture installed, it makes the wires hot but the lights still don't come on. - I'm sure the wiring is correct, as I've installed other three ways in my home with absolutely no problems.
Any ideas?
Jim Port 03-10-2011 08:03 AM
Without a way to return the current to its source the fixture will not work. You need to check all the connections. Sounds like you have lost the neutral.
cschwehr 03-10-2011 08:30 AM
If nothing has changed... It is likely as mentioned, a loose connection on neutral or you could check the switches to ensure they are functioning correctly, I've seen burnt out three-way's before. With a multimeter you can verify continuity between the common and each of the travelers depending on the switch. Do this with the switch removed.
You could check the neutral issue with a meter also... And I would physically look at the connections under all the wire nuts.
BBhomerepair 03-10-2011 09:05 AM
thanks!
I'll check the neutral wires tonight. that may just be it. in fact i'm almost certain of it. Thanks again!
