Old 11-10-2008, 03:03 PM   #1
DIYer
Post
My local AHJ on Smurf
I decided to make a new thread because the old one was getting really long. Here's what my local inspector said about how they consider smurf:
It is considered a form of conduit for physical protection of the exposed wiring. We generally will always accept this in a residential application; to have the romex covered is the key. Of course, there are always limitations, but if it is just to the receptacles and switches, water heater or furnace where the wires leave the wall cavity, it should be ok.
Surprisingly they accept it not on the grounds that unfinished basements aren't subject to damage, but on the grounds that "anything covering the romex" is enough protection.
Even so, I'm going to do any new work with EMT though. It does look more professional.
But this explains why my entire basement was done in smurf.
PS- Judging on what I read, do not assume that your local inspector will be of the same opinion, if you come across this message in google results or something.
Gigs is offline   Reply With Quote
Old 11-10-2008, 03:33 PM   #2
DIY'er
jamiedolan's Avatar
I just bought some for in wall / in celing use. It will only be exposed where it connects to the panel. It was just too much work to run EMT and wasn't worth it, and I am not ready to run the wires yet, but am closing up walls this week. 3 runs of 1/2 in Smurf was the perfect answer.
Jamie
jamiedolan is offline   Reply With Quote
Old 11-10-2008, 04:27 PM   #3
Moderator
Termite's Avatar
Thanks for posting your inspector's opinion...I always love to hear how these things turn out for people. Glad he's allowing you to do what you want, but he needs to freshen up on his NEC code knowledge...He's dead wrong.
Old 11-12-2008, 04:35 AM   #4
DIYer
Oh god, what have I done. Now the spammers think this is a site for smurf costumes.
Was my local lumber yard being straight with me? RolandOG Building & Construction 6 05-28-2008 02:00 PM
Need advice on meeting with a local shop CowboyAndy Electrical 30 03-24-2008 07:21 PM
Second story 3DPiper Building & Construction 3 03-28-2007 10:33 AM
Local 33 Boston / stolen tools Jimj Carpentry 2 07-02-2006 12:04 AM
