My Light Fades Dimmer To Brighter - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2011, 04:36 PM   #1
Rewards Points: 87
my light fades dimmer to brighter
Hello all:
I have a reading light (about 40watts) which I use to read before turning out the light at night to sleep. I've noticed sometimes the light fades for a few seconds and then gets bright again. There's no one using power elsewhere so the only thing it could be is fridge, furnace or water heater kickin in and drawing power. Any ideas?
Thanking you in advance.
momof2labs is offline   Reply With Quote
Old 02-27-2011, 04:41 PM   #2
Licensed electrician
Rewards Points: 1,010
If this happens all over the house youu need to call your power company ASAP. If it only happens on one circuit in the house you need to look for a loose neutral connection either in the panel or as part of the circuit wiring.
momof2labs (03-15-2011)
Old 02-27-2011, 04:53 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,096
Are you really sure theres nothing else drawing power,
like a pump or motor ?
If not it sure sounds like a loose connection some where !
Could even be the lamp base.
Try another lamp.
Try another outlet.
dmxtothemax is offline   Reply With Quote
Tags
dimming light , electrical brownout
New 20 amp braker to panel. Can I use 14 gauge from dimmer to light fixture? nlako Electrical 6 02-11-2011 09:38 PM
Can Any Ceiling Fan Work With A Dimmer Light Switch BlessedMomma Electrical 10 01-25-2011 07:45 PM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
Dimmer Switch, Energy Saving Light Bulbs PCMLR Electrical 6 10-11-2010 12:04 PM
Dual light switch dimmer? techprincesse Electrical 9 07-03-2010 12:40 AM
