My House Eats Lightbulbs - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2011, 10:25 PM   #1
Rewards Points: 264
My house eats lightbulbs
For some reason, my house destroys lightbulbs. Mainly in the bathroom and kitchen - I don't think the problem is with the bulbs, I think the fixture or the power to the fixture is somehow screwed up.
Does this make sense? I got floros thinking they might hold up better and they actually fared worse - about a week, and they are supposed to be like 10,000 hour bulbs or something ridiculous.
Any ideas how to fix this?
tibberous is offline   Reply With Quote
Old 08-09-2011, 11:04 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,504
Many things can contribute to premature lamp failure,
Most likely is too high voltage.
Have you tried using high voltage light bulbs ?
You can get them thru electrical wholesalors/distrubutors.
Other things like excess vibration or heat can also
cause problems.
If you think it is a problem with high voltage,
or even spikes and surges then getting an electricain
to check out the system would be wise.
dmxtothemax is offline   Reply With Quote
Old 08-10-2011, 03:50 AM   #3
Electrical Contractor
kbsparky's Avatar
Bad sockets can cause excessive heating with literally "cooks" the bulb from the base. Even CFL's can blow out, if the connection is bad enough.
Try replacing one of the offending fixtures, and see if the problem goes away.
-KB
Old 08-10-2011, 07:33 AM   #4
Rewards Points: 1,538
Measure the voltage. Quantitatively using a voltmeter, not only qualitatively using a circuit tester with just some little lights.
AllanJ is online now   Reply With Quote
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
New house drywall DISASTER pharm07 Off Topic 13 03-25-2011 02:24 PM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 10:01 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
