My House Eats Light Bulbs - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 07:16 PM   #1
My house eats light bulbs
So it seems that my house enjoys a steady diet of incandescent light bulbs of all type. It's blowing bulbs all over the house, some even no more than two weeks old. I've had my utility company come out to check my service at the pole twice, but that hasn't resolved the problem. Any ideas what may be causing this? It definitely seems to happen more in the warmer months than the cooler ones.
Thanks,
Ash
oatlord is offline   Reply With Quote
Old 06-28-2011, 07:38 PM   #2
Rewards Points: 1,418
Have you measured the voltage?
Do the same light bulbs come on very brightly some of the time and dim some of the time?
Are the light bulbs in a first floor ceiling that gets a lot of vibration from walking up above?
Old 06-28-2011, 07:44 PM   #3
I haven't measured the voltage at the lights, but the outlets in my house get between 120 - 123 volts.
Most of the lights that have had issues are in ceilings or fixtures that wouldn't receive any vibration.
They do dim at times, however. I haven't noticed an increase in brightness though.
Old 06-28-2011, 11:08 PM   #4
Electrical Contractor
Buy bulbs rated for 130 volts.
You'll have more luck with those.
hpp58 is offline   Reply With Quote
Old 06-28-2011, 11:09 PM   #5
kbsparky's Avatar
Cheap fixtures with bad sockets.
The lamp sockets are typically riveted together, with the rivets acting as wire terminations as well as structural.
Carefully look into the sockets, and you may see signs of scorching where the rivet attaches to the shell. That indicates a loose/bad connection, usually for the neutral conductors.
Such bad connections can cause excessive heating in the socket, literally cooking any light bulbs from the base resulting in short lamp life.
Try replacing one or more fixtures, and see if that helps.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
oatlord (06-29-2011)
Old 06-29-2011, 09:39 AM   #6
jbfan's Avatar
Rewards Points: 138
To add to what KB said, if the lights are on the same circuit, look for loose connections in the panel, and at the first switch location.
jbfan is online now   Reply With Quote
Old 06-29-2011, 11:34 AM   #7
Rewards Points: 1,520
Originally Posted by WillieWalsh View Post
Buy philips bulbs rated for 100 volts.
Why 100 vs. 130 v?
bob22 is offline   Reply With Quote
Old 06-29-2011, 12:05 PM   #8
Master Electrician
Rewards Points: 3,678
Not a good idea.
brric is offline   Reply With Quote
Old 06-29-2011, 02:24 PM   #9
Tizzer's Avatar
Rewards Points: 452
Wouldn't higher rated bulbs than what the fixture requires, continue to blow bulbs from getting too hot.
Tizzer is offline   Reply With Quote
Old 06-29-2011, 02:24 PM   #10
Thanks for all the replies. I think KBSparky is probably correct in that it's cheap fixtures. They're original to the 16 year old house, and were probably construction grade when they were put in. I'll start replacing them slowly and see if that solves the problems for good.
Old 06-29-2011, 02:30 PM   #11
Master Electrician
You are confusing voltage versus wattage. A 60 watt bulb is a 60 watt bulb whether it is a 120 volt bulb or a 130 volt bulb. A 130 volt lamp(bulb) will usually last long in a circuit supplied with 120 volts.
The Following User Says Thank You to brric For This Useful Post:
Tizzer (06-29-2011)
Weird wiring in house fdmillion Electrical 13 06-14-2013 07:49 PM
LED Flood light bulbs? CoconutPete Electrical 7 03-29-2011 06:01 PM
Light bulbs blowing,,, Woodcutter Electrical 12 09-15-2009 07:24 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
