05-15-2012, 02:56 PM
#1
Wire Chewer
My first time playing (literally) with mains power
Well, not counting the time I got zapped as a toddler, this was the first time I played with 120vac.
I found this little gem in my tool box the other day, I can't believe I still have it.
That is not just a paper clip shaped in a funny way, it is a light socket.  I was like 10ish, maybe 12 at the time. I had been playing with batteries and stuff for a long time, and had the urge to try something more exciting. So I screwed in a christmas bulb into the rounded part, insert the end into the socket while holding the bulb as to not touch the metal, and then I'd use a wire to go from the end of the bulb to the other socket part and it would light up.
From there I kinda grew out of control until my parents were scared I'd start a fire.
I follow codes now.
05-15-2012, 04:16 PM
#2
that reminds me of the first time i tried to "test" a gfci years ago before i understood how it works.
stick a wire in each receptacle slot and "run" the other wire ends through a bowl of salt water. gfci didnt trip, but breaker did. still not sure what i was trying to prove
i obsess about codes now
05-15-2012, 04:18 PM
#3
Wire Chewer
You're suppose to run the hot only in the salt water and put your hand in it while touching the faucet.
05-15-2012, 04:19 PM
#4
knew i did something wrong! loud pop was pretty exciting though.
PS to others dont try either my or red squirrel's little tricks at home
05-15-2012, 05:18 PM
#5
Learning Things Every Day
Damn.
Under Construction
05-15-2012, 05:22 PM
#6
Wire Chewer
Good point I should have said that in case someone thought I was serious.
Chances are it would work and the GFCI would do what it's designed to, but it's just not a safe way to test at all!
05-15-2012, 05:54 PM
#7
Electrical Contractor
I always had to see how stuff worked as a kid. When I was about eight I got my own small tool set and it went bad after that took apart everything in the house I could get my hands on.
Caught hell for a lot of things mom went to use the phone it was in pieces. I can't even count how many times I took something apart.
Then about ten I started to actually fix some stuff and try to make different things with 120v to 12v transformers. Radio Shack became my favorite store. And I grew into doing more and more as I grew up.
My family was terrified the first time they caught me pluging in a transformer and playing with some switches lights and motors.
I remember doing it at my grandparents house on the dining room table. Was like check out this gadget then plugged it in and started to play around. They thought I was crazy. And after talking to my uncle about what I knew he finally agreed it was ok for me to do what I was doing.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
05-15-2012, 06:32 PM
#8
Just a DIY guy
as long as we are all confessing ... this happened when I was about 7 or 8.
After opening an electric clock I was playing with the bare ends of its power cord that were disconnected somehow. I put the two ends into the clock, got an arc and a pop, and blew the breaker (thankfully!).
"WHAT HAPPENED TO THE BREAKER???"
I never said a word. And I stopped playing with appliances.
I hope my own kids survive their ignorance.
05-15-2012, 06:34 PM
#9
Wire Chewer
Haha yep that's how I was as a kid. I had what I liked to call a "lab" was really just a play area,had christmas lights and all, and everything was powered by a switch board I had made using real switches and crunched up foil paper as wires. As a kid I could not just go to a store and buy whatever, so I was resourceful and went in the kitchen and grabbed pieces of foil. I had seen it done in "Honey I shrunk the kids" where they use foil to jumper two terminals in a radio and I'm like "holy crap I can use that for wires!".
This one time I wired something wrong and plugged it in, I got a crazy light show. Sparks, and the whole foil turned blue, it was awesome, so I did it again on purpose.
I think this may be how I got my red hair.
05-15-2012, 07:08 PM
#10
Has anyone ever managed to avoid a 120v shock? Has anyone had one of 220v or higher?
05-15-2012, 07:33 PM
#11
Wire Chewer
Actually my first 120 shock was with that little thing I posted. My hand had slipped and I touched the metal. Weirdest feeling ever.
I was also curious to see what a short circuit with 120v looked like. Wow that scared the crap out of me the first time I did that.
I've never felt a 240v shock though. I was talking with an electrician who did the electrical where I worked and I asked him if he ever got hit with 600v and he said "it makes you sit down".
05-15-2012, 07:41 PM
#12
Semi-Pro Electro-Geek
I have only ever had one 120V shock, and it was last fall. I got careless and had a knuckle bump a bus bar in a panel. That's 30 years without a line voltage shock, despite working on electronics since I was a kid! I did have several significant run-ins with other voltage sources though, including some very hefty capacitors that could have been quite serious (but luckily weren't). I'm generally very careful.
05-15-2012, 08:11 PM
#13
well done mpoulton. ive been shocked maybe 5 times in 7 years. but ALL of these occurred when I was (1) rushing (2) partially distracted or (3)both
05-15-2012, 08:17 PM
#14
I=E/R
When I was a kid I had an Erector Set. In it was an electromagnet with two wires. I know now they were to be connected to a battery but I thought a duplex receptacle would work. One big puff of smoke. I don't remember getting shocked pushing the wires in but of course they were insulated with enamel coating
05-15-2012, 10:13 PM
#15
Worst was a 240v shock from a wet saw pump. Luckily it was all slippery and I barely had a grip and after what felt like forever but was not long it fell out of my hand and my whole arm hurt for a week.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
