Old 01-28-2013, 09:30 PM   #1
My first inspection - Do you see any problems?
So I decided to install a Reliance transfer switch and a remote inlet to use with my generator. I got it all done, and now it's time to get it inspected. This is the first time I'm having an inspection done on work I've done myself, so I'm not sure what to expect. I think I should be OK, but I figured I'd share some photos here in case there is something obvious I missed.
I followed manufacturer's instructions along with some advice I picked up here on the forum. I ran about 50ft of 10-3 romex between the transfer switch and the inlet box.
So what do you guys think?
My first inspection - Do you see any problems?-dscf5932.jpg   My first inspection - Do you see any problems?-dscf5934.jpg   My first inspection - Do you see any problems?-dscf5936.jpg
LVDIY is offline   Reply With Quote
Old 01-28-2013, 09:34 PM   #2
Send a message via AIM to theatretch85
Is that inlet installed in an attached or detached garage?
theatretch85 is offline   Reply With Quote
Old 01-28-2013, 09:36 PM   #3
Attached. Does it make a difference?
Also, just for the record and before someone else asks: I am not running the generator inside the garage...
Old 01-28-2013, 09:38 PM   #4
It would if you used standard romex to a detached garage in a wet location underground.
Old 01-28-2013, 09:40 PM   #5
That makes sense. The wire is running across the basement and then up through the wall to the attached garage.
Old 01-28-2013, 10:20 PM   #6
deverson's Avatar
I'd suggest duct seal in the LB to keep CO from going into the basement. Yes I know it's only a 3/4" conduit. But that's what I would recommend.
deverson is offline   Reply With Quote
Old 01-28-2013, 10:34 PM   #7
Thanks! Not a bad idea, although the only way my garage will get CO exposure is if I can get all the junk out so I can actually pull a car in
The Following User Says Thank You to LVDIY For This Useful Post:
electures (01-29-2013)
Old 01-28-2013, 11:44 PM   #8
Did you buy covers to replace any breakers no longer being used?
http://www.amazon.com/Industrial-Sys...N%3DB000NNMTLW
They just snap right in the holes.
Old 01-29-2013, 12:22 AM   #9
UAW SKILLED TRADES
Stubbie's Avatar
There will not be any unused breakers ....
Old 01-29-2013, 06:49 AM   #10
He might ding you on the romex in the conduit.
danpik is offline   Reply With Quote
Old 01-29-2013, 06:59 AM   #11
Licensed Electrician
k_buz's Avatar
Why? Its legal as long as it's not outdoors.
Location...Location...Location
The Following User Says Thank You to k_buz For This Useful Post:
Old 01-29-2013, 07:17 AM   #12
A "Handy Husband"
rjniles's Avatar
Seems to be a common misconception that NM (ROMEX) or UF can not be run in conduit.
Coastal South Carolina
Old 01-29-2013, 07:38 AM   #13
There are no changes to any breakers in the panel, so there are no unused open spaces once the cover is back on.
The Romex only runs in conduit up the wall in the garage and up the wall in the basement in order to protect the wire. I checked that on the forum here before I did it, and it sounded like that would be OK.
janvi: what??
Old 01-29-2013, 07:42 AM   #14
Master Electrician
That section of Greenfield needs to be secured.
Mark
Licensed Master Electrician
Commonwealth of Virginia
busman is offline   Reply With Quote
Old 01-29-2013, 08:00 AM   #15
Mark
What's Greenfield?
97 acura 3.2 TL with multiple problems vonbismarck Automotive Repairs 5 02-14-2012 12:00 AM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Home Inspectors / Non Disclosed Issues PreSale AndrewF Off Topic 14 02-06-2009 11:18 PM
Determining whether or not you have foundation problems? rmartin1286 Building & Construction 8 01-23-2009 09:09 AM
Are you having ice problems? Grumpy Roofing 27 02-17-2008 04:51 PM
