My Electrician Walked Out On Me - Electrical - Page 8 - DIY Chatroom Home Improvement Forum
Old 09-12-2012, 07:05 PM   #106
here's a photo of the panel... what's going in the circled area?
also, other than the hots not being connected to the breakers (for the most part) does anyone see anything amiss with this panel?
thanks[/QUOTE]
That appears to be a ground/neutral buss. Why is there a black wire going to it? Normally black wires are hot and don't go there
davidcee is offline   Reply With Quote
Old 09-12-2012, 07:14 PM   #107
Electrical Contractor
kbsparky's Avatar
If the black wire is a grounding electrode conductor, it can be black, bare, or pink-polka-dotted purple. It's not required to be green.
-KB
The Following 6 Users Say Thank You to kbsparky For This Useful Post:
brric (09-12-2012), frenchelectrican (09-12-2012), jbfan (09-12-2012), Speedy Petey (09-12-2012), stickboy1375 (09-12-2012), zappa (09-12-2012)
Old 09-12-2012, 09:43 PM   #108
Not sure what country you are in & what code book you use but where I come from ground conductors are either bare or green or white but never black or polka dotted
Old 09-12-2012, 09:52 PM   #109
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Well, since you have no location in your profile either then I guess you are not in the US under the NEC.
250.62 Grounding Electrode Conductor Material.
The grounding electrode conductor shall be of copper, aluminum, or copper-clad aluminum. The material selected shall be resistant to any corrosive condition existing at the installation or shall be protected against corrosion. The conductor shall be solid or stranded, insulated, covered, or bare.
Nothing about color.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
brric (09-13-2012), concretemasonry (09-12-2012)
Old 09-12-2012, 09:57 PM   #110
Also, grounding conductors are NEVER white.
Grounded conductors (neutrals), yes.
Grounding electrode conductors, sure, if you want.
Old 09-12-2012, 10:43 PM   #111
Master Electrician
In Canada anything #2 and smaller is supposed to be either green or green with yellow stripe. Anything larger has to be identified with green or green with yellow stripe. This wasn't always the case though. Used to be able to use black marked with green tape for any size ground. The neutral in the ground bar would be a no no here to most inspectors.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 09-12-2012, 10:51 PM   #112
jbfan's Avatar
Rewards Points: 478
Thats not a ground bar per say.
That panel has 2 neutral bars, one on each side, connected by a strip under that black that runs from bar to bar.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
brric (09-13-2012)
complicating-updating new box for client, electrician messed it up-pics included Kraze Electrical 29 11-18-2012 09:14 PM
Licensed Electrician or Not? taras1 Electrical 10 04-29-2011 06:23 PM
Do I Need to Call in a Electrician to Check This Work? taras1 Electrical 6 12-13-2010 05:07 PM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 08:39 AM
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 07:07 PM
