02-20-2013, 10:51 AM
#16
Is my electrician trying to KILL ME?
S
Originally Posted by Speedy Petey
Absolutely not. What does them being 240V have to do with it?
Say 240 30 amp load of compressor motor? I thought not, but asked.
02-20-2013, 11:04 AM
#17
Semi-Pro Electro-Geek
The wiring in the panel appears to match the diagram. The 20A circuit is 240V-only and the 30A circuit is 120/240. How did you have it before? Did you follow the diagram? What makes you think there's something wrong?
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
02-20-2013, 01:03 PM
#18
Licensed electrician
Unless all the wiring is inside the ground should not be bare.
02-20-2013, 01:50 PM
#19
Licensed Electrical Cont.
Originally Posted by Hardway
S
Not all 240V loads are heavy draw.
Just being 240V means nothing, other than the load is typically pretty well balanced.
02-20-2013, 04:33 PM
#20
I don't understand this. What do you mean?
I can learn as easily as teach.
02-20-2013, 04:40 PM
#21
Wiring to a hot tub on the exterior of the house needs an insulated grounding conductor. The interior portion can be bare.
02-20-2013, 05:23 PM
#22
I guess I don't understand how a 2 pole GFCI works. I am looking for reassurance that the GFCI will function properly wired without a neutral wire. Is that true??
I still don't like how he just wrapped the hot tub ground around ground wire instead of taking it back to the buss bar. I cut it too short to reach the buss bar. Would it be OK to wire nut another short pig tail to it and reattach it directly to the buss bar?
BTW, The tub is located in the garage. (for now)
02-20-2013, 05:28 PM
#23
Electrical Contractor
I think that would be a good idea.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
The Following User Says Thank You to rrolleston For This Useful Post:
02-20-2013, 05:34 PM
#24
YES, a GFI WILL work without a load neutral connected.
The LINE neutral (white tail) from the breaker must still be connected to the neutral bar.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
#25
2 pole gfi needs the 'line neutral' pigtail connected to the neutral bar, but does not require a 'load neutral' attached to the screw on the breaker
The Following 3 Users Say Thank You to Techy For This Useful Post:
02-20-2013, 05:44 PM
#26
Yes you can extend the ground wire with a wire nut to reach the bus.
#27
OK now I'm ready to come down out of my tree and let the wife and kids enjoy this thing.. I really appreciate the help. Again thanks a TON.
02-20-2013, 09:20 PM
#28
If he didn't want to kill you before !
He might want to now,
after he see's the post !
Some folks might not like someone saying,
" there trying to kill someone"
02-21-2013, 12:08 AM
#29
I would have to think his sensibilites couldn't be that delicate if he's leaving hot tub ground wires unhooked. He can call me and complain if he recognizes his work..
02-21-2013, 07:15 AM
#30
Some folks are just too over-dramatic for their own good.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
