My Electrician Friend... - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-20-2008, 04:35 PM   #16
Power Gen/RS Engineer
Rewards Points: 566
Rusty-
I'm a bit confused...
You and your buddy installed this feeder 8 years ago but now you're thinking that it is illegal and therefore you want to add the ground?
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 07-20-2008, 04:49 PM   #17
Rewards Points: 392
Originally Posted by BigJimmy View Post
Rusty-
Actually, 8 years ago we did this install and soon after I had a very bad accident. It's taken me a long time to pull my life back together and now I have a lot of time to study things (not necessarily a good thing). I have some pretty serious equipment in my shop and just want to make sure everything with the electric is proper before I start using the equipment. Thanks BigJimmy
rustyjames is offline   Reply With Quote
Old 07-20-2008, 05:50 PM   #18
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
Originally Posted by Cow View Post
Poor advice.
You didn't ask when the installation was performed to see if it met code when installed. And you want him to replace his existing conduit even though an 1.5" pvc can hold up to 6 #2 wires??
Rustyjames, follow John's advice. This used to be a VERY common installation.
There is a difference between being allowed to put 6 #2 in 1.5" conduit and acctually being able to do it. Why would you want your max in there first of all second is do you know how hard it would be to pull all those wires through?
Pudge565 is offline   Reply With Quote
Old 07-20-2008, 07:28 PM   #19
Rewards Points: 392
Tell me about it; like I said it wasn't easy pulling the 3 #2's in the 1.5" conduit, I couldn't imagine double.
Old 07-20-2008, 07:45 PM   #20
Master Electrician
JohnJ0906's Avatar
Rusty, there's nothing wrong with wanting it to be safe.
Just check the things I posted above. If you can, take some pictures of the shop panel and post them here.
If properly done, this is safe, and you can move on to some other projects.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 07-20-2008, 07:58 PM   #21
Rewards Points: 392
John,
Thanks. I'd be too embarassed to show anyone a photo of what I have now, it's a mess and that's why I'm concerned. I have another question that I'll post tomorrow about my service panel feeding the shop. It was brutally hot here today so I'm going to hit the rack!
Old 07-20-2008, 08:57 PM   #22
Cow
You're missing the point Pudge. I gave the max allowable wire fill just to show how far UNDER the maximum he was.
Cow is offline   Reply With Quote
Old 07-21-2008, 12:06 AM   #23
Pudge565's Avatar
Rewards Points: 150
Ok cow but I was just throwing that out there.
Old 07-21-2008, 02:46 AM   #24
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Rusty
Look at this diagram....if this complies with what you have, the installation is safe and NEC approved. When your jurisdiction takes up the 2008 code then anything installed now will need 4 wires. There are 100's of thousands of 3 wire feeders in existance, don't be paranoid your present installation is just fine. Take heed to Johns suggestion about bonded neutral and ground, make sure the panel is configured as shown below.
Any mess would have to be at the panels, so I am assuming you mean poor condition or bad wire management at the panel. Your wires can be as messy as you want as long as they are terminated correctly. Fixing that is not a big deal. But if messy is unsafe then posting some pictures will help us advise you. Believe me those of us here in the trade have seen just about everything so throw a photo at us and we will help you out..... No.... we will be glad to help you out.
Old 07-21-2008, 05:46 AM   #25
Master Electrician
JohnJ0906's Avatar
Originally Posted by Stubbie View Post
Rusty
Thank you for the picture Stubbie.
John from Baltimore
One Day at a Time
Old 07-21-2008, 09:15 AM   #26
Rewards Points: 392
Stubbie,
Thanks for taking the time to post that diagram. The situation I have now is looking in the box is like looking at spaghetti; it bothers me and I want to get it proper. The current sub-panel is an old Pushmatic so that will be getting switched to a Square D QO. I'll post pictures as the installation progresses.
Old 07-21-2008, 11:07 AM   #27
UAW SKILLED TRADES
Stubbie's Avatar
Hi Rusty
Hey... that kind of messy is good when you change a panel out.....means your wires are probably longer than they need be....makes for an easier time reconfiguring the new panel as needed...... btw QO is a very good panel upgrade you will like it.
complicating-updating new box for client, electrician messed it up-pics included Kraze Electrical 29 11-18-2012 10:14 PM
help electrician failed to show.NEWB post gotsig Electrical 25 05-26-2008 10:28 PM
electrician sticker bullet Electrical 10 02-24-2008 11:49 AM
North Carolina Electrician assistance please buloni Electrical 2 12-03-2005 09:07 PM
