Old 08-13-2012, 06:34 PM   #16
My CEILING FAN just fell on the couch, HELP!
Originally Posted by louweed View Post
why do i need a whole new fan? can't it just be re-wired? assuming i will have to hire an electrician to come over to do it .
but why does the screw come untightened. I know for certain that screw was very tightened and for over a year no problems..
cdowling1 is offline   Reply With Quote
Old 08-13-2012, 06:38 PM   #17
here's the damage. I am not DIY savvy by any means, but does anyone think I (novice) can reconnect this thing?
ps, sorry about the cobwebs. help!
mine did the same exact thing it was a hunter Newburgh fan and has been up there for over a year hung by a professional and never wobbled or caused a problem until it fell and hit me
Old 08-13-2012, 06:58 PM   #18
Mad Scientist
I've never been a fan of those set screws. Seems most newer fans attach the downrod much more securely. A couple drops of loctite on those set screws would be good insurance, I think.
McSteve is offline   Reply With Quote
Old 08-13-2012, 07:04 PM   #19
E2 Electrician
stickboy1375's Avatar
Originally Posted by McSteve View Post
I've never been a fan of those set screws..
neither was the fan.
The Following 3 Users Say Thank You to stickboy1375 For This Useful Post:
a_lost_shadow (08-14-2012), Evstarr (08-13-2012), McSteve (08-13-2012)
Old 08-13-2012, 11:55 PM   #20
louweed is offline   Reply With Quote
Old 08-14-2012, 12:21 AM   #21
" Euro " electrician
frenchelectrican's Avatar
I am not too crazy with screws as well I never understand why not just make a pin that go thru the pipe then the sucker will never come off instead of useing the locktie it may work it way loose over the time but I never like the combo head ( which that use the phillps and flat blade ) at all just use the standard nut and lock it good with a wrench it much stronger than just a combo head.
I have ran into one good ceiling fan that have three setscrews that sucker can not come apart very easy without destory the pipe.
Merci,
Marc
frenchelectrican is online now   Reply With Quote
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 10:27 PM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 01:10 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
