My Breaker Keeps Breaking - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-22-2009, 04:54 PM   #16
Code05's Avatar
Rewards Points: 1,104
Originally Posted by 300zx View Post
Did you change out the outlets? As every one has said you have a dead short if you take the five rec out and look at how they are conected Brass screw black wires-Silver screw white wires then you have your green ground .Like the video http://www.youtube.com/watch?v=bDhYD...eature=related Or do you know where the first rec is after leaving the breaker? You could take out the five outlets Put wirenuts on each wire Then turn on the breaker and see if that clears the problem if it does then turn breaker back off and put the closest rec back together and so on
Jag, this a good starting point, have you tried it yet? If the breaker trips with no connected load, the s0b hack electrican cut the wire somewhere else. If it trips, do not try resetting it twice! Report back with results. We can help you fix this, but you need to make sure this goes against his license.
Code05 is offline   Reply With Quote
Old 09-23-2009, 08:34 AM   #17
Hey I just wanted to thank everyone for brainstorming and coming up with some great information.
I went back as you guys said to trouble shoot and it turns out the guy that did the wire cutting and stuffing put a staple in to hold the wire where it was to hide it and the staple he put in tore through the old wiring, so I replaced the wire and tested and and everything is working great.
Lets just hope there are no more suprises
jagne03 is offline   Reply With Quote
Old 09-23-2009, 05:32 PM   #18
300zx's Avatar
Post
I would Still cantact St.louis better business bureau File a complaint http://www.bbb.org/us/ Let them know how Unhappy you are with him And Congratulations on the fix.
300zx is offline   Reply With Quote
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
Breaker problem jdhar Electrical 11 06-10-2009 01:18 AM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
