My Bathroom Set Up, And Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 10:07 PM   #1
Rewards Points: 150
my bathroom set up, and questions
my parts: exhaust fan, vanity light, shower recessed trim light, 20 amp breaker, 12/2 wire, single pole switch (15 amp), gfci receptical (20 amp), single pole dual switch (2 toggles, 15 amp), new work single gane for outlet and double gang for switches
my set up: service panel up to gfci receptical connecting only one end of the gfci and pigtailing it. Pigtailed to double gang box with single swich and dual switch to provide power (total of 3 switches). In the double gange box: whites are pigtailed all together. ground is pigtailed all together. black from the power feed that goes from the outlet to the double gang switch box is pigtailed to give me 3 black wires to provide power to each switch. One black of those 3 pigatiled goes to the line screw single switch, vanity light black wire goes to other black connector on single switch. now single switch is done. On the double toggle switch both black from pigtailed goes to provide power to switch, then exhast fan black goes to hot screw and the shower light black wire goes to another.
is there any problem with having 20 amp breaker, 12/2 wire and 20 amp gfci and using a 15 amp switch?
Sorry if this sounds confusing, I have tried my best to explain it.
does this set up sound ok?
fabian is offline   Reply With Quote
Old 01-25-2009, 10:50 PM   #2
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
Sure, no problem, as long as the light fixtures they're controlling don't exceed 15 amps. Just add up the wattage of each of the bulbs and divide by 120 (volts).
For example, (4) 60 watt light bulbs = 240 watts. 240 watts/ 120 volts = 2 amps.
404.14 (B)(1)
Magnettica is offline   Reply With Quote
Old 01-26-2009, 08:16 AM   #3
Rewards Points: 150
cool, thanks. but the set up sounds correct right?
Old 01-26-2009, 08:23 AM   #4
Rewards Points: 150
Your setup sounds just fine.
Steelhead is offline   Reply With Quote
Old 01-26-2009, 08:24 AM   #5
Rewards Points: 150
thanks guys!
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 02:56 PM
A few questions about bathroom flooring and repair dsnider420 Flooring 1 10-30-2008 09:21 PM
Tiling a bathroom and hallway questions Roddy Piper Flooring 11 02-07-2008 03:35 PM
Basement Bathroom Rough-in questions Bmbeeson Plumbing 16 12-29-2007 01:41 AM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
