MWBC's For Dedicated Circuits? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2011, 08:38 PM   #1
Rewards Points: 81
MWBC's for Dedicated Circuits?
Hi, my house has a lot of MWBCs and I've learned to embrace them.
Curious to know if MWBCs are prohibited when associated with dedicated circuits required under 2011 NEC.
Keep in mind you need a 2 pole, common trip breaker for MWBCs as of late.
On the one hand I think it's common to use an MWBC to a well pump/tank pump setup. That's a fine idea, you wouldn't want one pump to start while you're working on the other, anyway.
On the other hand it might not be the best idea for an attic furnace, where a dedicated circuit for the heater and a separate dedicated circuit for an outlet nearby is called for. If the heater is tripping the breaker, you might need a trouble light or power tool to fix it. There are probably much better examples of places where it wouldn't be smart.
Specifically I'm wondering about dishwasher and garbage disposal.
Whatchyathink?
-Jeff
mysterylectric is offline   Reply With Quote
Old 07-07-2011, 09:01 PM   #2
Licensed electrician
Rewards Points: 1,020
One important item to consider is whether or not AFCI protection is required. Two pole AFCI breakers are not common.
Old 07-07-2011, 09:03 PM   #3
I can't speak to MWBCs in the 2011 NEC, I am sure that someone much smarter than me will be able to help you with that info.
I can speak to a MWBC on a garbage disposer and a dishwasher as that is what I did in my house. Many people are opposed to any MWBCs anyplace, I think that they are a great way to save a few bucks on wire and in this application it makes for a very nice clean installation if you use a duplex plug with the tab removed. Just my 2 cents
Another great application fr MWBCs is the outlets above the counter in the kitchen, again just my 2 cents.
regularguy is offline   Reply With Quote
Old 07-07-2011, 09:09 PM   #4
Rewards Points: 1,418
You run into some complications with GFCI protection on multiwire branch circuits also.
Specifically the continuation of protection from the load terminals of a GFCI receptacle to additional receptacles cannot be part of the MWBC any more.
Now (both sides of) the MWBC can continue from the line side of a GFCI receptacle with additional GFCI units used downstream where needed.
Or a double pole GFCI breaker can be put in the panel to protect the whole MWBC.
Old 07-07-2011, 10:09 PM   #5
Master Electrician
Rewards Points: 3,678
Whatchyathink?
-Jeff
2 pole common trip circuit breakers are not required for MWBC's
brric is offline   Reply With Quote
Old 07-07-2011, 10:11 PM   #6
Master Electrician
There is absolutely no problem with GFCI's on MWBC's if one knows what one is doing.
Old 07-07-2011, 10:17 PM   #7
They are in Ontario, Canada.
Old 07-07-2011, 10:21 PM   #8
Master Electrician
cool......
Old 07-07-2011, 10:22 PM   #9
Electrician
Rewards Points: 760
Wildie is the an Ontario rule, if you go by the CEC you don't always need a two pole breaker.
darren is offline   Reply With Quote
Old 07-07-2011, 10:42 PM   #10
Rewards Points: 324
2008..210.4(b).multi wire branch ckts,shall have a disconecting means that will simontainously open all ungrounded (hot)conductors at the point of origination.
oleguy74 is offline   Reply With Quote
Old 07-07-2011, 10:45 PM   #11
Licensed Pro
That doesn't mean common trip, just tied handles.
Old 07-07-2011, 10:46 PM   #12
Rewards Points: 324
that what common trip is...
Old 07-07-2011, 10:51 PM   #13
Master Electrician
No it isn't. Single pole breakers with handle ties are acceptable.
Old 07-07-2011, 11:01 PM   #14
" Euro " electrician
frenchelectrican's Avatar
Either way it will work.
Two single pole with handle tie or a two pole with common tripping device ditto with three pole verison.
Basically it almost the excat the same in our French codés.
Merci,
Marc
Old 07-07-2011, 11:06 PM   #15
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
On dedicated circuits that don't require AFCI or GFCI, I usually run a MWBC or two single circuits and break the tabs. I figure, if I need a 15 or 20 amp outlet now, maybe later I'll need more power.
Moving multiwire circuits WillK Electrical 5 06-21-2011 08:12 PM
Split receptacles, double pole breakers and multiple circuits in a junction box. morganhammer Electrical 6 04-05-2011 05:38 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 11:07 AM
AFCI and 3-wire circuits...ugghh mhops Electrical 11 03-17-2010 12:22 PM
Adding odd circuits in a bedroom and hood fan oh my! beatle Electrical 3 11-19-2009 08:45 AM
