MWBC (split 220V) -- Code And Good Practices - Electrical - DIY Chatroom Home Improvement Forum
Old 06-26-2011, 05:41 AM   #1
MWBC (split 220V) -- code and good practices
Here is a follow-up question to my earlier barn wiring question. When using MWBC to provide two, 110V circuits, can the two hot wires (poles) be used to also provide power to a 220V device? This question is about both code and good practices.
My underlying concern is if one of the 110V circuits was running a motor, would the phase shift be enough to cause problems (like over heating) with the 220V device. That device in this case would also be a motor (1HP at 220V).
John
john4153 is offline   Reply With Quote
Old 06-26-2011, 07:29 AM   #2
Electrical Contractor
Motor should be feed by it's own 240 volt circuit
hpp58 is offline   Reply With Quote
The Following User Says Thank You to hpp58 For This Useful Post:
john4153 (06-26-2011)
Old 06-26-2011, 11:13 AM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
The motor alone requires #14 wire with a 20A breaker.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-26-2011, 02:44 PM   #4
All wiring is 12 gauge and the breakers are 20A. The two poles for the MWBC would be ganged to work together.
When you say "alone" do you mean the motor must have its own circuit and breaker, or do you mean the minimum wiring to the motor (including the 110V circuits) is 14 gauge?
John
Old 06-26-2011, 02:52 PM   #5
electures's Avatar
John
Seperate circuit for the motor. #14 is compliant, but #12 is fine also.
The Following User Says Thank You to electures For This Useful Post:
Old 06-26-2011, 03:26 PM   #6
Thanks to you both. I drew it up this afternoon, and the motor will have a separate circuit.
John
