MWBC And Double Taps - Electrical - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 03:19 PM   #1
Rewards Points: 77
MWBC and double taps
Included a pic that will hopefully help.
I have 2 cables that have 3 wires each, each cable is sharing a neutral(MWBC).
the 2 wires with the green line is 1 cable.
the 2 wires with the blue line is the other cable.
I wanted to remove "wire 4" because i wanted the breaker space and im rewiring the family room, and wire 4 will only have 1 outlet and 1 bulb on it, which could be added to another circuit.
Ignore the wire marked "seperate circuit". i can move that.
My goal was to have that "wire 4" breaker slot empty and eliminate double taps.
Breakers are GE type TQL, cant find anything about them listed for 2 wires.
Ive been reading about MWBC and i guess im just looking for the simplest answer. can use a tandem breaker for each mwbc?
am i screwed, should i just leave it alone and find another slot to use?
myabe pigtails?
Please let me know if i can furnish more info, its kinda hard to get it from my head to my keyboard.
bryan1282 is offline   Reply With Quote
Old 01-03-2012, 03:40 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,172
Sorry but I am lost, all the lines look green.
A MWBC is connected to a 2 pole breaker (or 2 single pole breakers on different legs). Meaning the red wire is connected to 1 pole and the black wire the other. I see 2 black wires connected to 1 single pole breaker and 2 red wires connected to another. That is not a MWBC.
Or are you saying you have 2 different MWBC's connected to the same 2 breakers?
Coastal South Carolina
Old 01-03-2012, 03:40 PM   #3
Julius793's Avatar
If you know what your doing with mwbc than you can use a quadplex beaker. Remember each leg of the mwbc needs to be on a separate phase!!
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-03-2012, 03:47 PM   #4
Rewards Points: 77
1 black and 2 red is one cable.
3 red and 4 black is another cable.
the 2 wires with the electrical tape on each is 1 cable entering the panel.
Old 01-03-2012, 04:04 PM   #5
Rewards Points: 1,492
As I saw it the two multiwire branch circuits are connected to three different breakers.
The setup should be modernized with both MWBC's connected to the same double wide double breaker with handles tied together (or each MWBC connected to its own double wide double breaker with handles tied together).
Did someone mention a double wide quad breaker with handles 1 and 4 tied together for one MWBC and handles 2 and 3 tied together for the other MWBC?
A single wide double (tandem) breaker may not be used for both legs of one MWBC.
Old 01-03-2012, 04:43 PM   #6
Rewards Points: 77
Yes, 2 MWBC on 3 breakers. lol, im trying to make a space and now i might have to use up 4 slots just for these cables....i hate the electrical in my house. ive fixed so many bad things already. i like the quadplex breaker idea. it only takes up 2 normal slots right? like the one in the pic. im not afraid to do the work as long as there are some instructions with the breaker or someone gives an answer here.
The breaker in the pic, 1 and 4 is for one MWBC and 2 and 3 is for the other MWBC?
Old 01-03-2012, 05:18 PM   #7
Choose a breaker where, if you flip #1 off then #4 also goes off (and vice versa) and if you flip #3 off then #2 also goes off (and vice versa).
Old 01-03-2012, 05:25 PM   #8
Rewards Points: 77
sounds good to me. eleminates the double taps and i can still make a space available.
MWBC to detached Garage Lacklustre Electrical 1 11-16-2011 04:44 PM
Multi Wire Branch Circuit MWBC w/4X or 6X hots or more, 1X oversized neutral mysterylectric Electrical 7 05-05-2011 10:16 PM
Double-tapped breaker and MWBC sirsparksalot Electrical 5 04-04-2011 02:28 PM
2 Single Poles to 1 Double GFCI Breaker nuckphoto Electrical 24 11-10-2010 11:40 PM
MWBC bad neutral test results! kbsparky Electrical 15 04-06-2010 08:44 AM
