MWBC On 2 Gfci's - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2014, 07:27 PM   #1
Rewards Points: 455
MWBC on 2 Gfci's
Is there a creative way of making 2 -120v gfci receptacles work off a 12-3 mwbc which feeds 2 - 120v circuits without 1 or the other tripping ?
Cletis is offline   Reply With Quote
Old 01-06-2014, 07:35 PM   #2
deverson's Avatar
Rewards Points: 77
Nope! Unless you install GFCI receps in place of all receps on the circuit.
deverson is offline   Reply With Quote
Old 01-06-2014, 07:39 PM   #3
Idiot Emeritus
Rewards Points: 1,492
Are the two GFIs in the same box or different ones, and are there GFI protected circuits fed from one or both GFIs?
Basically, you feed one of the GFIs with black and white of the 12/3, and the other with red and white.
If there are receptacles downstream from either GFI, they need to be on separate 12/2s, each one connected to the load side of each GFI.
You can't use 12/3 on the load side of a GFI; the neutrals cannot be shared.
Rob
micromind is offline   Reply With Quote
Old 01-06-2014, 07:40 PM   #4
Licensed electrician
Rewards Points: 1,892
Yes, you just pigtail the neutral before splitting into two circuits.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
brric (01-07-2014), mpoulton (01-07-2014), rjniles (01-06-2014)
Old 01-06-2014, 08:25 PM   #5
Should have looked at the posters name. I think we are being trolled.
jbfan (01-06-2014)
Old 01-06-2014, 08:51 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
I wondered the same thing.
Coastal South Carolina
Old 01-06-2014, 10:39 PM   #7
joed's Avatar
Rewards Points: 13,766
No problem. You use white and black on one receptacle and red and white on the other receptacle. You can not do split wired receptacles.
Need Advice on MWBC jacksstack Electrical 5 06-11-2013 02:35 PM
MWBC to Garage Questions benleef Electrical 3 02-22-2012 11:02 AM
Line to line load on a MWBC? rjniles Electrical 13 12-09-2011 07:09 AM
GFCIs on MWBC? harry_ho Electrical 17 10-28-2011 01:18 PM
Compact GFCI's?? humberguy Electrical 5 06-09-2010 08:38 AM
