Must I Solder Old Wire Connections? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 10:00 PM   #1
Question
Must I solder old wire connections?
Thank goodness for a site that provides such consumer DIY advice! Through one link I've discovered that a GFI between old and new wiring will protect the circuit. But I've also read that the proper way to join the old cloth-wrapped two wire cord is by solder. Does this apply to making the GFI connection? All help is appreciat4ed
meloday is offline   Reply With Quote
Old 01-24-2011, 10:08 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
If you are in the US, it is not legal to have a joint that depends on solder only for it's means of connection. Solder was used quite a few years ago before the invention of Wire-Nuts
We don't use solder anymore.
A gfi will not protect the circuit. That isn't what it is designed to do. It is for personnel protection.
Explain what's you are doing and you will probably get a few suggestions as to the best way to do things.
just a note: you cannot extend a circuit that does not have a equipment ground conductor (EGC; ground wire). Not sure what you are doing but was thinking that might be applicable to your situation.
Old 01-24-2011, 10:36 PM   #3
nap
Thanks for the reply. I suppose I was not very clear... I have an old home with mixed wiring. most is new but some is not. The electrical circuit box is no more than 5 years old. I do have one old wire wire running out of the circuit box, into the pump house (which is connected to the house but not floored or well insulated) and then returning to the house where it powers several fixtures. When I asked about joining old and new wires I was referring to several posts like this: "Receptacles in homes wired without grounding can have receptacles replaced with GFCI receptacles.Its not necessary to replace all the recpts. as any outlets that are wired 'down stream' from GFCI recpts. are protected also."
Just so you know I won't do this myself but I want to know what SHOULD be done. I, like the electrician who put in the panel to start with, don't feel a need to re-wire the few affected receptacles. But i would like to have the pump removed from the circuit...and that means old and new wires will meet.
On This Old House they say old wires should be joined with solder then heavily taped because the connection is better. But what do I know? That's why I'm asking!
Old 01-24-2011, 10:55 PM   #4
nap
You talking to me?
nap's Avatar
Solder hasn't been used for electrical wiring for probably 50 or so years. The only time I run across it (and I am an electrician by trade) is when I work on very old buildings.
The National Electrical Code (the electricians bible) specifically does not allow a wire joint that is made with only solder.
In the situation with the GFCI's. Yes, you can install one and it can protect up to 4 or 5 (you have to read what your GFCI receptacle is rated for) more receptacles fed from that one GFCI receptacle.
I don't know where This Old House is coming up with a soldered connection. It just isn't allowed in the manner they suggest.
The Following User Says Thank You to nap For This Useful Post:
meloday (01-26-2011)
Old 01-25-2011, 12:16 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
This Old House has been the source of some of the WORST advice I have ever seen or heard. How those freakin hacks stay on the air is beyond me!
Norm knows his furniture, that's about it!
Speedy Petey is online now   Reply With Quote
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
frenchelectrican (01-25-2011), Saturday Cowboy (01-26-2011)
Old 01-25-2011, 11:49 AM   #6
Rewards Points: 1,418
A joint to be soldered must not pull apart easily prior to the application of the solder.
A properly done solder joint is better electrically than a wire nutted joint. A significant disadvantage of solder is that it is cumbersome to undo if you want to modify or replace something.
Twisting wires together (either hot wires or ground wires) is not sufficient by itself; either solder or some compression device such as a wire nut is needed.
Stranded wires can also be held together with wire nuts.
Old 01-25-2011, 12:00 PM   #7
If you are just removing the pump wiring from the junction box, then old wires and new wires already met there. Either that was improper to begin with or the "new" wires were "old" enough to be grandfathered. Ideally you wanted to run a new cable from the circuit box to the pump shed junction box to connect with the "new" wire going back into the house.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 01-26-2011, 08:07 PM   #8
I appreciate all the input. I was much more confident when I hired an electrician. All tasks were done and done both quickly and correctly.
Tags
connecting , gfi , old house , solder
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 09:36 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 02:23 PM
Overheated Wire Connections In Stove Top chef Electrical 5 09-06-2008 07:35 AM
