Murray Orange 200 Amp Main Pannel Shutoff - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-15-2009, 02:41 PM   #31
Electrical Contractor
If the wire is rated it will have a marking on it. You can use that marking to determine the allowable ampacity of the wire.
ohmy is offline   Reply With Quote
Old 10-15-2009, 02:45 PM   #32
300zx's Avatar
Post
Not that i know of dont have code book with me right now but dont think you can. are you going alum or copper ? They both will bend pretty easy Take a piece of pipe that the wire fits in and bend it to what you want should work i have done this before
300zx is offline   Reply With Quote
Old 10-15-2009, 07:38 PM   #33
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by murray1 View Post
Again I wish to thank everyone who has helped me. I was at home dpot yesterday and they have the connectors show by 220/221 so that is no problem, I notices on the packaging that they were rated for both aluminum and copper. I looked at wire when I was there both aluminum and copper 3 guage they are both very stiff I can probably bend them around to fit as I will have to splice them to the old wires and than come down the side of the box ( on the inside of cource) across the bottom and up the side and than bend them to go into the end of the 200 amp breaker. I was wondering if it would be possible to use 3 guage welding lead wire which has much finer strands and is much more flexable with a much heavier insulation than the wire at Home depot and still stay in code. Thanks Al
Just want to make sure that with 200 amp service you must have to use 3/0 CU or 4/0 Al conductor you can not use the #3 AWG with 200 amp service you will burn up the wire way before the breaker will react to it.
Merci,Marc
Old 10-15-2009, 08:54 PM   #34
Can't you find any slack in those cables? I would consider unscrewing the panel from the studs to see if I could easily slide the whole mess up a few inches to gain some wire.
Don't use welding cables or anything other than the right product which is #2/0 or #3/0 depending on your location/application, not #3
Read the existing cable and you can go one size smaller if you are going to copper.
PS
1) That is going to be a mess if you extend the feeders down around the bottm. I would yank them out, cut them really short, install the splice couplings, heat shrink and tape them, then reinstall them in a direct line to the breaker, possibly using a new KO directly above the breaker on the right side of the panel.
2) WTF is that coming out the bottom, individual conductors?
220/221 is offline   Reply With Quote
Old 10-15-2009, 09:40 PM   #35
Thumbs up
Hi sorry that the pics are sidways but you get the idea. I live just uoutside of Portland Oregon. I am aware that I will have to get the power company up to shut off the power in the white box with the meter. the box has a power company seal and a label saying do not open as it contains metering equipment
Exactly as "frenchelectrician" said. I was puzzled myself. If this is an Overhead service. Where is the (invisible) "Drop"?! Merci Beaucoup Monsieur Electricien de la Republique Francaise!!! You learn new things every day!
Eliminate confusion Through Education.Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 10-15-2009, 10:05 PM   #36
Sparkplug:
De rien.
{ you are welcome }
Merci.
Marc
Old 10-15-2009, 10:39 PM   #37
Originally Posted by frenchelectrican View Post
Sparkplug:
De rien.
{ you are welcome }
Merci.
Marc
Transliterated; For nothing: Translated; You are welcome! C'est la meme chose..! (No matter what)Don't Drink and Drive, Ever!!!
Last edited by spark plug; 10-16-2009 at 02:42 PM. Reason: Corrected French Spelling
Old 10-16-2009, 01:50 AM   #38
I am sorry for the confusion it is my ignorance on the correct terminology of wire sizes. I will us either #3/0 or #4/0 for the extensions. It was those sizes of wire I was looking at at home depot that I mentioned was quiet stiff. I agree that it will be very crowded if I run the extended cabls around the inside of the box, Tomorrow I will look and see if I think there is enough room to do as 220/221 sugested I tried but there is no slack in the wires coming into the box. I will also check out the sugestion of moving the box up Thanks for all the good Ideas I appreciate the help. Al
murray1 is offline   Reply With Quote
Main water shutoff problem GoodoleBob Plumbing 18 06-16-2011 11:33 PM
Dual Main Breakers dcwestcott Electrical 3 02-23-2009 08:26 PM
Breaker box has no main shutoff. SubSailor Electrical 15 02-27-2008 07:01 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
