Murray/Bryant Circuit Breaker And Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2010, 07:52 AM   #1
Murray/Bryant Circuit Breaker and Panel
Panel is Murray and Breakers are Bryant. Service is about 40+ years old. Tried to replace 15/15 and 20/20 breakers with Murray and cutler hammer but both do not fit.I do not believe that Bryant is produced anymore. Is there a current replacement of do I have to go to the aftermarket. If it is aftermarket, how specific do I have to be to get the exact replacement?
Jfr0521 is offline   Reply With Quote
Old 06-25-2010, 09:08 AM   #2
I=E/R
a7ecorsair's Avatar
Your panel should have a model number and say what type of breaker is used. I have a 30 amp double pole breaker that was purchased at Ace Hardware and is Labeled and Listed for use in some Murray, Westinghouse, General Electric, Siemens, Challenger, and Thomas & Betts panels.
So, what does the label on your panel tell you?
a7ecorsair is offline   Reply With Quote
Old 06-25-2010, 11:51 AM   #3
Licensed Pro
If you are trying to replace tandem breakers (two breakers in one case), you may have a panel that does not accept CTL tandems, but the ones previously used were a non-CTL design, meaning they will fit in a panel that is not designed to limit the number of tandems (typical of older panels). Look for a tandem breaker that is "non-CTL" listed, and expect to pay 2-3 times as much.
Old 06-25-2010, 07:49 PM   #4
Electrical Contractor
kbsparky's Avatar
You are apparently using BD1515 and BD2020 breakers, which are CTL type.
Try the BR1515 and BR2020 type which are non-CTL type. They will cost 3 times as much, however.
-KB
Circuit Breaker Panel Height? helpless handyman Electrical 25 02-24-2014 03:06 PM
Old Electric Panel/ Circuit Breaker Box dankreboot Electrical 3 12-16-2008 12:52 PM
Replace a service panel circuit breaker knockout? michigan_homeowner_2008 Electrical 6 05-22-2008 04:01 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
