Multiwire Branch Circuit Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-15-2014, 03:14 PM   #16
Rewards Points: 1,832
Originally Posted by Cletis View Post
MWBC's should never be used in residential as they are highly dangerous in could result in an unnecessary fatality if altered by a non electrician.
http://ecmweb.com/content/multiwire-...n-be-dangerous
Which is why the NEC now requires the breakers feeding them have handle ties.
Originally Posted by skobydog View Post
The entire house is wired this way. I'm slowly fixing them room by room but can only do so much in the day.
There is nothing wrong with this code wise. Cletis likes to ask all the tuff questions and likes to make us think twice. Whom ever wired you home was actually doing you a favor. You can plug an iron on the top vacuum or space heater on the bottom and not worry about anything.
Only issue is if the neutral becomes open. However, as long as it doesn't this type of system will work flawlessly. Its used near 100% of the time in commercial even on much higher voltages like 277/480 and 347/600.
Jump-start is offline   Reply With Quote
Old 06-15-2014, 03:19 PM   #17
YEs, it's all dangerous, but, mwbc's should not be installed in residential because the propensity of diy's, maintainance, and HO's not knowing what they are doing can cause more than normal catastrophic effects. Until the day that only highly skilled electricians that are highly trained to work on mwbc's are allowed to do electric on residential (like myself), mwbc's should be banned until further notice...
I still remember your posts from ET...
Old 06-15-2014, 03:29 PM   #18
Originally Posted by b4bhomeowner View Post
MWBC don't play nice with *FCI breakers (required in many rooms by current NEC). One good reason not to use them in residential, aside from the experience factor.
GE took out the 30ma protection:
http://apps.geindustrial.com/publibr...ET-719|generic
Old 06-15-2014, 03:44 PM   #19
Rewards Points: 158
I rewired my kitchen only because I basically gutted it. I had to move a number of outlets, added GFCIs, and numberous other things.
I'll leave the multi branch circuits in the rest of the house now that I understand them. Thanks
skobydog is offline   Reply With Quote
Old 06-15-2014, 04:22 PM   #20
As long as they are on separate legs (there is 240 volts between the black and red) plus the neutral isn't disconnected while the circuit is still live you are ok. Id leave them if you are ok with them. If youd like you can actually use them yourself when adding new circuits. A piece of 14/3 or 12/3 costs less than 2 12/2s or 14/2s when you need more than 1 circuit. Very economical. You could call an electrician's secret in saving wire.
Just of note. If you are adding circuits or changing breakers in your panel they will need handle ties since code now requires both black and red to be disconnected at the same time for safety. That way you don't shut off one circuit thinking its all off only to find a live wire in a box. Home Depot and Lowes generally don't carry handle ties, however, you can use a double pole breaker instead. It is allowed by code and meets all the requirements.
Old 06-15-2014, 04:49 PM   #21
Rewards Points: 1,192
You need to get new receptacles with the jumper in place.
bobelectric is offline   Reply With Quote
Old 06-15-2014, 04:58 PM   #22
Rewards Points: 158
While I'm at it, I'm sure this has been answered before so sorry.
I see that I'm supposed to tie the breakers together and I also see under Section 210.4(D) that the cables are to be cable tied together in the panel.
What I'm not clear on installation of GFCIs. My old wiring (no GFCIs) had every receptacle split (all receptacles had the tabs broken). The tops were fed by one breaker and the bottoms by another.
Would I not do this with GFCIs?
Sorry if this is obvious. It's my first time ever working with MWBCs and every receptacle in my house is split with one breaker for the tops of the outlets and another for the bottom.
Old 06-15-2014, 05:00 PM   #23
Rewards Points: 158
Yes, thanks
Old 06-15-2014, 05:24 PM   #24
Rewards Points: 3,396
Shouldn't have to bundle or hand tie or any of that
It's all existing.
The gfci. Pigtail the white and go to the receptacle.
Pigtail one of the circuits to the gfci.
Splice the other circuit to run through the box
ritelec is offline   Reply With Quote
Old 06-15-2014, 06:17 PM   #25
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Manufactures are stepping up with more available products.
Old 06-15-2014, 06:35 PM   #26
FIDO...
Rewards Points: 241
Over the winter, I put my kitchen's MWBC on a AFCI breaker (Eaton CH215CAF), and the two having been playing together perfectly fine.
Cheers, Chris
Chris130 is offline   Reply With Quote
Old 06-15-2014, 06:37 PM   #27
Rewards Points: 158
What I previously had was a Kitchen Split Receptacle Circuit (from what I understand).
Would this be correct for installing 6 GFCI receptacles on a multi branch circuit? All receptacles would be GFCI and all connections would be on the line side of the receptacles.
Is this correct? (Grounds are not pictured) Thanks
Old 06-15-2014, 06:51 PM   #28
You got it
Old 06-15-2014, 07:12 PM   #29
Rewards Points: 158
Originally Posted by ritelec View Post
You got it
Old 06-15-2014, 07:15 PM   #30
Licensed electrician
Rewards Points: 1,766
Skoby, a GFI cannot be split wired like your old setup.
SER Cable for Branch Circuit & Wire Size sdmuleman Electrical 2 04-02-2014 11:02 AM
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
Circuit Breaker Troubleshooting Question - need help! DanLeonard Electrical 4 10-01-2012 11:20 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Wire size for dryer jamiedolan Electrical 14 01-15-2009 05:43 AM
