Multiwire Branch Circuit Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2014, 09:10 AM   #1
Rewards Points: 158
Sorry about the TINY pics.
The home is currently wired as a multibranch circuit with all of the top receptacles on one breaker and the bottoms on another.
What I'd like to do is make the 4th outlet in the chain on a separate breaker and the other outlets on another breaker. I was going to make that one receptacle for my a/c
First pic is the way it is wired now. Second is what I'd like to do. Any issues with doing this?
Multiwire Branch Circuit Question-untitled.jpg   Multiwire Branch Circuit Question-untitled2.jpg
skobydog is offline   Reply With Quote
Old 06-15-2014, 09:34 AM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Not a problem, just ensure that all the neutrals are pigtailed together, at each junction box.
The Following User Says Thank You to stickboy1375 For This Useful Post:
micromind (06-15-2014)
Old 06-15-2014, 09:43 AM   #3
Rewards Points: 158
Cool, I figured it would be ok but wanted to make sure. Thanks
Old 06-15-2014, 09:53 AM   #4
Rewards Points: 455
MWBC's should never be used in residential as they are highly dangerous in could result in an unnecessary fatality if altered by a non electrician.
http://ecmweb.com/content/multiwire-...n-be-dangerous
Cletis is offline   Reply With Quote
Old 06-15-2014, 10:10 AM   #5
Rewards Points: 158
The entire house is wired this way. I'm slowly fixing them room by room but can only do so much in the day.
Old 06-15-2014, 10:28 AM   #6
E2 Electrician
There is nothing wrong with it being wired that way...
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
Canucker (06-16-2014), micromind (06-15-2014)
Old 06-15-2014, 10:57 AM   #7
Rewards Points: 455
What about this
http://www.nfphampden.com/mbc.pdf
http://www.homeinspector.org/resourc...h-Circuits.pdf
http://activerain.trulia.com/blogsvi...andem-breakers
Old 06-15-2014, 10:58 AM   #8
E2 Electrician
What about anything? It's all dangerous, and why live circuits should never be worked on. I've seen electricians open up neutrals on MWBC's, and lets not forget the fact that every service is a MWBC...
The Following 3 Users Say Thank You to stickboy1375 For This Useful Post:
Canucker (06-16-2014), micromind (06-15-2014), sgip2000 (06-16-2014)
Old 06-15-2014, 11:05 AM   #9
Rewards Points: 455
YEs, it's all dangerous, but, mwbc's should not be installed in residential because the propensity of diy's, maintainance, and HO's not knowing what they are doing can cause more than normal catastrophic effects. Until the day that only highly skilled electricians that are highly trained to work on mwbc's are allowed to do electric on residential (like myself), mwbc's should be banned until further notice...
Old 06-15-2014, 11:07 AM   #10
E2 Electrician
Yes, nice trolling....
danpik (06-17-2014), tylernt (12-11-2014)
Old 06-15-2014, 11:07 AM   #11
Master Electrician
Rewards Points: 3,678
MWBCs are not dangerous. Untrained people mucking with them are dangerous.
brric is offline   Reply With Quote
The Following 7 Users Say Thank You to brric For This Useful Post:
Canucker (06-16-2014), danpik (06-17-2014), Jim Port (06-15-2014), micromind (06-15-2014), sgip2000 (06-16-2014), Stubbie (06-15-2014), tylernt (12-11-2014)
Old 06-15-2014, 11:08 AM   #12
E2 Electrician
Same lines go for Electricity in general.... no need to limit the categories....
Old 06-15-2014, 11:30 AM   #13
Rewards Points: 455
What about electricians giving DIY's electrical advise ? Aiding and Abetting ?
Old 06-15-2014, 12:17 PM   #14
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Aiding and abetting a safe installation or code compliant answer to avoid otherwise. Homeowners (DIY) come here to get clarification and help those that don't take the time and think they understand are the ones that open neutrals on multiwire branch circuits, wire them wrong or tap them incorrectly.
You, me nor the NEC can prevent stupid. Besides the NEC cannot consider untrained people working on electrical installations.
Would you rather have homeowners giving other homeowners electrical advice without oversite by a professional?
Forums like this exist for those who recognize they are not skilled in electrical but seek professional help or correct answers. Aside from that it is a given that homeowners are going to do the electrical work with or without advice from a professional.
I take a lot of pride in this forum and the work we do here. It's like a classroom for DIYers who want to learn how and work safely on the electrical in their homes and projects.
As for MWBC there are literally thousands currently installed. They have great advantages in some installations. They are not used as much anymore in residences but they are not unsafe ... that is the wrong word.
What you are really saying is that many homeowners don't have a clue what an MWBC is and decide to wire something up anyway. As a result they get themselves into a pickle. That's stupid not unsafe .....
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following 5 Users Say Thank You to Stubbie For This Useful Post:
Canucker (06-16-2014), Chris130 (06-15-2014), jbfan (06-15-2014), Jim Port (06-15-2014), micromind (06-15-2014)
Old 06-15-2014, 12:34 PM   #15
Rewards Points: 131
MWBC don't play nice with *FCI breakers (required in many rooms by current NEC). One good reason not to use them in residential, aside from the experience factor.
b4bhomeowner is offline   Reply With Quote
SER Cable for Branch Circuit & Wire Size sdmuleman Electrical 2 04-02-2014 12:02 PM
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 03:04 PM
Circuit Breaker Troubleshooting Question - need help! DanLeonard Electrical 4 10-02-2012 12:20 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Wire size for dryer jamiedolan Electrical 14 01-15-2009 06:43 AM
