Multiwire Branch Circuit Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 03:26 PM   #1
Multiwire branch circuit question
Been lurking for a while, but finally found a question that I can't quite find an exact answer for.
During a recent remodel, I asked the electrician to run a couple circuits into the attached garage so i could add some outlets and lights (figuring maybe 4 outlets on one circuit 15amp, and a couple lights and an additional outlet or two on the other). I figured i do that myself to save some money. So I'm finally getting ready to start the project, and realized it's 14/3 coming into the box (black and red hots, white neutral, ground).
While i've done some simple electric work with one hot/one neutral, i'm not exactly sure what to do with the shared neutral. Is it as simple as wirenutting the neutral, so I'd just wire one run with black and the split neutral, and the other with the red and split neutral? Or do i just call the electrician back as this isn't something i should be messing with. As I passed electrical inspection from a thorough inspector, i'm fairly certain the wiring is all done correctly at the breaker box. Doesn't seem like it should be too hard, but I haven't been able to find the exact answer on fairly extensive searching.
palmerjoe is offline   Reply With Quote
Old 06-23-2011, 03:44 PM   #2
Too Short? Cut it Again!
Sometimes simple is all you need. This will work just fine.
Wet Bar Circuit question Straightgrain Electrical 8 12-31-2009 08:11 AM
Circuit breaker question kupalino Electrical 6 12-18-2009 11:35 PM
Yet another 3 way circuit question! sirkeen Electrical 4 07-28-2009 11:54 AM
Adding a branch circuit help glover10604 Electrical 8 09-09-2008 01:40 PM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 06:06 AM
