Multiple Neutrals One Lug - Electrical - DIY Chatroom Home Improvement Forum
Old 10-02-2012, 07:44 AM   #1
Rewards Points: 77
multiple neutrals one lug
Hi, Just lost power to my outdoor elec receptacle and assumed the gfci circuit breaker was bad but finally troubleshot it to the recept in the bathroom which was wired usng only the push in contacts and apparently branches off to the outside recept. I'll bet you electricians have seen that a million times. While in the panel, I noticed that there are several lugs with 2 and 3 neutrals under the same lug. I thought this was not allowed but the box seems to have provision for more circuit breakers than it does to accomodate all the grounds and neutrals. (Federal Pacific 100 amp about 35 years old) Doesn't look like any way off adding additional ground bus. Any advise for me? Do you consider the multiple neutrals a dangerous condition or should I leave it alone.
Also.. Would there be any pro or con to ditching the gfci circuit breaker and installing a gfci in the bathroom instead? Which is the better way to provide the ground fault protection.? Thanks
SS396 is offline   Reply With Quote
Old 10-02-2012, 08:03 AM   #2
Licensed electrician
Rewards Points: 1,272
The rule is one neutral per hole. This was not very clear in the way it was in the code. Now it is clarified.
The GFI protection can be provided by either the breaker or a GFI receptacle.
I don't see why another ground bar could not be added to give you room for the neutrals.
Wire multiple lights to multiple motion sensors? w4audi Electrical 3 02-09-2012 03:26 PM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
Multiple neutrals for same circuit ericdube Electrical 2 07-19-2009 12:54 AM
Feeding multiple subpanels with a single generator monsoon Electrical 8 10-02-2007 05:25 PM
connecting multiple neutrals toghether best way? J187 Electrical 4 08-17-2006 10:35 AM
