Multiple "Main" Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 04-28-2009, 08:22 PM   #1
Lightbulb
Multiple "Main" breakers
Two big questions:
1: my old service interrupt [box right after meter] has 2 100 amp fuses [yes, fuses]. Does this make it a 200 amp box or 100 amp?
2: If I want to have two separate breaker panels in the house [single structure] what would a wire diagram look like from after the meter to each "main" breaker? Or do I have to run one breaker as a sub panel?
The reason for the two panels is due to the design of the house. The Great Room divides the entire house in two with two bedrooms [one used as office] and a bath on one side [same side as SEP] and the other side of the house has a bedroom, bath, kitchen, laundry, garage, etc. So I want to run one "big" wire to that part of the house since the roof rafters are all that is there to go through. So I was thinking of splitting the service to two panels. Thoughts!
jbriskin is offline   Reply With Quote
Old 04-28-2009, 09:26 PM   #2
Electrician
Rewards Points: 760
You have a 100A service, you don't add up the fuses.
I would go from that disconnect to a panel(it can be either a main breaker or main lug panel). From this panel go to your subpanel.
Remember the only place your ground and neutral are connected together is in your disconnect. In your first panel the neutral will have to be isolated from the ground.
darren is offline   Reply With Quote
Old 04-28-2009, 09:52 PM   #3
Union Electrician
goose134's Avatar
True, unless the main panel IS your disconnect. To wit, a breaker type panel, instead of main lug only.
goose134 is offline   Reply With Quote
Old 04-29-2009, 11:13 PM   #4
Electrician
Rewards Points: 760
Goose i do agree with you, i have in my mind his panel hooked up after his fuseable disconnect.
Arc Fault breakers (warning) Potomac101 Electrical 68 01-05-2012 04:22 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 01:58 PM
Subpanels & cutler hammer arc fault breakers MoreCowbell Electrical 13 04-04-2008 11:19 PM
Sub-Panel or Tandem Circuit Breakers? dgoldsmith Electrical 2 03-08-2008 01:34 PM
Zinsco breaker boxes and breakers. evosounds Electrical 3 07-29-2007 07:08 PM
