Multiple Lines To Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 03:31 PM   #1
Rewards Points: 160
I currently have 2 12 gauge lines running from the house to the garage. Both are buried UF. One of the lines is only for 2 exterior lights, everything else including a shed and pool.
I'd like to make one of the lines power only the outlets, and the other line to power everything else. How do I wire this in to a subpanel? Digging and putting in conduit/new wiring would be difficult and expensive.
matt151617 is offline   Reply With Quote
Old 09-21-2011, 03:37 PM   #2
Rewards Points: 1,538
Technically you are allowed only one line of any given kind from the house to any one detached building such as a garage. For best results it should be a 120/240 volt circuit (one neutral) aka multiwire branch circuit. (120 volt only and 120/240 volt circuits are all treated as the same kind; a 480 volt line would be a different kind.) For buildings daisy chained togehter (perhaps with sub-subpanels) only one path from any one building back to the main panel is allowed.
For now, the 12 gauge lines handle 20 amps each and no subpanels are required.
Old 09-21-2011, 03:40 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
You have a code violation as you are not allowed to have more than one feeder to an outbuilding. There is no way to add a sub panel with the existing wiring. I would leave what you have and live with it.
Coastal South Carolina
Old 09-21-2011, 04:06 PM   #4
Rewards Points: 160
Actually I looked wrong. I have 12/2 UF feeding a subpanel that powers everything and 12/3 Romex that connects a light switch in the house and garage. Is there definitely conduit? I can't find any evidence of it on either end.
Also, how about disabling the UF and wiring up the Romex as the feeder line with a dual 20 breaker? Then I would have double the amps in the garage (and would only loose the switch in the house).
Old 09-21-2011, 04:09 PM   #5
Yes you could use the 12-3 as the feeder from house to garage. If buried (whether or not in conduit) it must be rated for burial e.g. UF.
Old 09-21-2011, 04:20 PM   #6
I=E/R
a7ecorsair's Avatar
Are these lights controlled by a switch that is in the house?
a7ecorsair is offline   Reply With Quote
Old 09-21-2011, 04:56 PM   #7
Rewards Points: 160
It's not UF, it's maked "sunlight resistant romex".
That line connects one switch in the house and one in the garage that power exterior lights. The actual power comes from the subpanel.
Old 09-21-2011, 06:17 PM   #8
A "Handy Husband"
rjniles's Avatar
Romex (a brand of NM cable) is not rated for direct burial or use in buried conduit(wet location).
Old 09-21-2011, 07:32 PM   #9
Rewards Points: 160
Yeah, I understand it's not rated for burial. However, there's no good way to get new wiring to the garage. Either I go about 15 feet straight from the panel, but it's all asphalt. Or I can go about 100 feet around the side and try to dodge the septic tank. And I still have to cross a sidewalk. And both methods involve drilling through the house and garage foundation.
Old 09-22-2011, 07:56 PM   #10
Rewards Points: 160
Looked at the wrong NM. This one says "ETTCO NM". It has a weird coating on it but it doesn't look like UF and it's not labeled that. I still think I will use it, run a dual 20 breaker off the panel, use the original UF line as the light switch inside, and get rid of the switch outside.
Old 09-22-2011, 08:33 PM   #11
If your city is still using the NEC of 2008 or earlier then the 2 wire cable can be used for a light on the house controlled by a switch in the garage or a light on the garage controlled by a switch in the house. That light subcircuit is preferably connected to power at the garage (ultimately fed by your 3 wire cable)
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
Garage floor Tomperro Flooring 6 07-18-2011 12:30 AM
Insulate finished garage ceiling or condition garage? pasichnyk Building & Construction 19 12-06-2010 01:46 AM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
