Multiple Lights Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 06:42 PM   #1
multiple lights wiring
hello, sorry i'm new here, i have a question i'm trying, and not succeeding, to wire 3 light on 1 switch.
the power comes from a receptacle, goes to light1, from there it splits and goes to light2, light3 and switch.
what i did is connect the HOT coming from the receptacle to the WHITE going to the switch.
the WHITE coming from the recept. is connected to all the WHITES.
and the remaining BLACK wires are all connected together.
what am i doing wrong?
please help, thanks!
gaia is offline   Reply With Quote
Old 04-14-2013, 07:54 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
How are the lights actually wired? does the switch go to light1 as well? if not, then you need xx-3 conductor between the lights.
Old 04-14-2013, 07:59 PM   #3
Rewards Points: 2,512
one drawing does not have 3 lites but you should get the idea.
Grounds not shown for ease of drawing
multiple lights wiring-1-switch-2-lites-all-switch.jpg   multiple lights wiring-3-lites-daisy-chained.jpg   multiple lights wiring-control-multiple-lites.jpg
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
gaia (04-14-2013)
Old 04-14-2013, 09:23 PM   #4
i don't know if it makes any sense to you guys, that's how i done it...
Old 04-14-2013, 09:35 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
From your diagram, it appears that you are tying the white wire and the bare wire together? If so, you need to separate the white (neutral) and the bare/green (ground).
Old 04-14-2013, 09:38 PM   #6
in my diagram there's no ground, i left it out. there's WHITE AND BLACK.
Old 04-14-2013, 09:39 PM   #7
k_buz's Avatar
It appeared you had 3 wires, now I see what you did. Your drawing looks correct.
Old 04-14-2013, 09:41 PM   #8
then the lights hate me! the one on the right never shouts off and the one at the bottom it flickers...
Old 04-14-2013, 09:51 PM   #9
k_buz's Avatar
Check you splices/connections again. The lights will work properly by the switch as you have drawn it.
Old 04-14-2013, 10:15 PM   #10
joed's Avatar
Rewards Points: 11,596
Your description sounds correct. What is not working?
Old 04-14-2013, 10:26 PM   #11
" Euro " electrician
frenchelectrican's Avatar
The most common cuprit will be useally wirenut splices., double check them to make sure they are tight and on in correct way.
Also double check at the luminaire location as well to make sure they are on good as well.
The diagram you post is correct but watch the room on one of the junction box ( this will depending on which type of junction box you used.)
Merci,
Marc
Old 04-14-2013, 11:33 PM   #12
thanks to everybody, i'll try again tomorrow
Old 04-15-2013, 07:07 AM   #13
If power is going to the upper plug on the receptacle, Could the tab be broken on the receptacle so that the lower plug has no power?
Old 04-15-2013, 07:23 AM   #14
k_buz's Avatar
None of the lights would at all then.
Old 04-15-2013, 07:33 AM   #15
OK..I must of browsed over the post where he said that one works, one flickers and one does not shut off.
Like others have said, the diagram in post #4 is correct. The question remains does the wiring you did match that diagram???
Wooden canopy for multiple pendant lights BurkeW Electrical 3 01-29-2013 03:20 PM
HELP!! 3 way wiring for lights with 3 zones BigSi Electrical 7 01-28-2013 11:10 PM
Wiring multiple fluorescent lights to a single wall switch. Hambone111 Electrical 3 12-30-2012 07:51 PM
Help with wiring: 1 switch controlling 2 lights streko Electrical 6 05-02-2012 10:43 PM
Multiple Motion Sensor Lights Tripping GFCI Wan Miguel Electrical 6 05-05-2010 12:01 PM
