Multiple Lights On A 3 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-07-2012, 01:59 PM   #1
CollinMc's Avatar
multiple lights on a 3 way switch
what did i do wrong; i connected multiple outdoor lights to an existing eave mount which has a single 3 way switch using 14 -2 wiring it worked fine of a few weeks but now trips the circuit breaker when turned on.
CollinMc is offline   Reply With Quote
Old 04-07-2012, 02:45 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Typically a 3 way switch isn't wired with a 14-2. Did you replace the switch?
If not, it would appear there is a short in the wiring or a burn out light bulb is shorting out. Anyway you look at it, if you didn't change the wiring at the switch and after you installed the new lights, it is starting to trip, something is wrong in the wiring of the lights or the lights themselves.
Old 04-07-2012, 03:19 PM   #3
CollinMc's Avatar
I didn't change anything just connected the 14- 2 to the existing 14-3 wiring ... thanks for you suggestions ... really hope one of em' resolves it
Old 04-07-2012, 04:55 PM   #4
joed's Avatar
Rewards Points: 12,028
It worked after you made the change or it tripped the breaker after you made the change?
If it worked for a time then something has shorted. Perhaps one of the cable clamps is too tight and cut the cable. Start disconnecting sections of the circuit and find which section is bad.
Old 04-07-2012, 06:36 PM   #5
CollinMc's Avatar
Gents it was a short (frayed hot wire) found it in the very first section of wiring. Thanks
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Multiple lights with one switch DIY Mark Electrical 1 12-03-2011 12:15 PM
Dimmer switch burned out my fan lights?? Dannery Electrical 1 09-14-2011 09:58 PM
Help with Two Switches & Two Lights simplyphp Electrical 36 11-25-2010 03:47 PM
Wiring Lights and Running Multiple Circuits in Conduit mark_anderson_u Electrical 0 11-02-2010 10:06 AM
