Multiple Light Switches On Existing Basement Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 11:41 AM   #1
multiple light switches on existing basement Wiring
I am in the process of finishing the basement and at the moment have 5 basement lights operated by one light switch powered by one power supply (new construction). How do you you add more light switches to the existing wiring?
fdasilva is offline   Reply With Quote
Old 05-30-2011, 07:08 PM   #2
Rewards Points: 1,442
You must string additional wires from the added switches to the respective lights.
Where does the power feed go to start things off?
AllanJ is online now   Reply With Quote
Old 05-30-2011, 08:01 PM   #3
Licensed electrician
Rewards Points: 1,242
Might I suggest you pick up "Wiring Simplified" so you can get some basic ideas of circuits and wiring.
Old 05-31-2011, 08:31 AM   #4
Jim,
I've already installed all the plugs but am a bit confuded about wiring existing lighting. Currently the power goes into one light and the other lights are ganged from this one light and all lights are controlled by one light switch. Is it as simple as adding additional swiches to the lights you want controlled, or do you need separate power sources for each sets of lights (connected by a light switch).
I don't want to rewire but will If required, as I know how to wire with distinct power sources.
Old 05-31-2011, 09:56 AM   #5
Allan,
There is currently one power source for all the lights.
Frank
Old 05-31-2011, 09:58 AM   #6
If one switch controls all the lights you will need to go back to a constant power source and run a new cable from there to the new switch. From the new switch you would run new cable to the fixture and disconnect or abandon the old wiring.
Old 05-31-2011, 10:02 AM   #7
Thanks Jim.
I had a feeling a new power source was needed for each string of lights so thanks for the confirmation.
Frank
Old 05-31-2011, 10:16 AM   #8
Without a new source of power the original switch would over-ride the new switches.
fdasilva (05-31-2011)
Old 05-31-2011, 10:30 AM   #9
Power comes into one light fixture and also cable to switch goes down from there.
Run a 3 conductor cable (14-3 if circuit is 15 amps) from each light fixture (except the first) to the desired switch location.
At each fixture (except the first) disconnect its black wire from the black power wire(s) coming through and connect it to the new black wire down to its switch.
Connect the new red wire to the black power wires passing through.
Connect the new white wire to the bundle of white wires (including that of the fixure).
At the fixture where the power comes in remove the black wire continuing on to the other fixtures from where it was and connect it to the incoming power wire. Whatever else was connected to the incoming power wire stays.
At each new switch box connect the red and black wires to the switch. Put a small wire nut or some tape over the white wire end which remains uncut and unconnected* for now.
*2011 code requires that the neutral go down to the switch box just in case someone wants to extend power from there later.
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
Wiring for replacing a bathroom fan, heater, light and night light unit. tgallopbs Electrical 24 11-02-2010 10:57 AM
Wiring bath fan to replace ceiling light quinten Electrical 3 10-31-2010 07:50 PM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 07:57 PM
adding an additional light to 2 3-way switches basement_guy Electrical 10 07-20-2008 10:23 AM
