Multiple Items On Load Side Of GFCI? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-29-2009, 12:39 PM   #16
Chicago, IL
Michael Thomas's Avatar
Is that clamp listed for Qty (1) 12AWG/2 cable and Qty (1) 12AWG/3 cable?
Some clamps are listed for Qty (2) 14AWG/2 NM cables, but not for Qty (1) 14AWG/3 cable and Qty (1) AWG/2 cable, nor for Qty (2) of anything larger, the listing for these will say something like:
"application: Indoors Only. Fits NM Cable: #14/2, #12/2, #12/3, AWG or 2 #14/2 AWG or Flex Cord .300 to .560 inches diameter 3/8" (1/2ko). Type: Twin Screw. In a dry location, use to connect nonmetallic sheathed cable to a steel outlet box or other metal enclosure. Miscellaneous: 3/8" size fits 1/2" knockout.".
I've never seen a municipal inspector kick about it, and electricians commonly clamp Qty (2) of 12AWG/x cables in them, but doing so does technically violate the listing for these clamps...
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 08-29-2009, 12:40 PM   #17
Originally Posted by BCSparkyGirl View Post
Them are some fancy pants connectors though!
@ fancy pants
ChristopherSprks is offline   Reply With Quote
Old 08-29-2009, 01:36 PM   #18
Rewards Points: 109
re: clamp
Sure is not correct. It's listed for one to two 14/2-12/2 cables and I am using 12/3 and 12/2. Good catch, THANKS!
BimmerRacer is offline   Reply With Quote
Replacing 8-Conductor GFCI SalomonDIY Electrical 9 08-12-2009 12:22 PM
GFCI intermittent nuisance trips jejm1975 Electrical 43 09-07-2008 09:18 AM
Side By side refrigerator Susie Q Appliances 6 08-31-2007 03:26 PM
moving another load bearing nailfun Carpentry 2 02-20-2007 08:10 AM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 09:31 AM
