#16 | |
Master Electrician
Multiple Grounding RodsQuote:
Sorry. Mark |
#17 |
Multiple Grounding Rods |
#18 |
Excellent. Now we know the whole story. Thanks.
#19 |
Master Electrician
Well, you can lie to yourself and believe you've met code, but unless you used a nonmetallic box and cover for your new installation, you have more than just the one code violation and a very unsafe installation. The GFCI does nothing to keep the box or cover from being energized by the incoming wires. Only proper grounding would do that.
Mark |
| The Following User Says Thank You to busman For This Useful Post: | mpoulton (11-29-2011) |
#20 |
Semi-Pro Electro-Geek
I would not be comfortable with this installation on my property. This is not the same circumstance as replacing a normal ungrounded receptacle with a GFCI. There is absolutely no protection to prevent the metal pole itself from becoming energized. That is an extremely dangerous condition to have, because any person or animal walking on the ground near the pole can be electrocuted without even touching it (google "step potential"). Touching the pole or even walking near it could be fatal. All it takes is a loose connection, worn insulation, or water in the fixture, and the whole thing will be hot. The only safe solution to this (aside from running new wire) is to use a GFCI circuit breaker, or feed the circuit from the load side of a GFCI back at the house. If I were you, I'd change it. This is a dangerous condition.
#21 | |
#22 | |
#23 | |
Now you mention conduit, though. That could change EVERYTHING. Is the circuit piped all the way back to the panel in metal conduit? If so, then it IS grounded/bonded - the conduit itself is the grounding conductor. You just need to properly connect the receptacle's grounding terminal to the conduit. |
| Display Modes | |
| Grounding multiple circuits/switches in one box | dalepres | Electrical | 12 | 10-01-2011 08:58 AM |
| Grounding rods for tv antennas | Wasatch Rebel | Electrical | 4 | 06-02-2011 08:23 AM |
| grounding rods for spas | scottyweis | Electrical | 48 | 09-13-2010 12:02 PM |
| grounding multiple service panels | dbusz | Electrical | 11 | 10-18-2008 01:32 PM |
| Anyone want to take a shot at why #6 to attach antenna ground to breaker? | Piedmont | Electrical | 44 | 01-08-2008 05:11 PM |
