Multiple Ground Rods, Help - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 02-14-2012, 02:43 PM   #61
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
That and if somebodies kids were out there playing around with dads cresent wrench(you know like most of us did! )and happens to pull the clamp lose on the 1st one the clamp will still be looped on the wire and the other end will still be hooked hopefully
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline
Old 02-14-2012, 03:00 PM   #62
Word of advice to everyone here. DO NOT hire any contractor that does not get permits and inspections. Even if the contractor claims it's not required. These kind of contractors are lazy and lazy contractors are the kind of people who will mess up any work they're doing and not even care. They are by no means professional. This is your house, where you live, you do not want people messing it up.
jasin is offline
Old 02-14-2012, 03:03 PM   #63
plummen's Avatar
It depends on what the job is,many places dont require a permit for jobs under $500.00
plummen is offline
Old 02-14-2012, 04:52 PM   #64
Master Electrician
Rewards Points: 3,874
Originally Posted by jasin View Post
I should not have to explain to a contractor the relationship between fully burring a ground rod and having a low-resistance grounding system.
In most cases grounding rods will NOT provide a low resistance grounding system. The code also says rods should me at least 6' apart not exactly 6' apart.
brric is online now
The Following 2 Users Say Thank You to brric For This Useful Post:
mpoulton (02-15-2012), Speedy Petey (02-14-2012)
Old 02-14-2012, 05:01 PM   #65
Master Electrician
Resistance depends on the soil conductivity and how deep the rod is buried not the fact that its a rod. Also, by code a second rod does not need used if the resistance is below 25ohms. see: Nec 250.53
No kidding?
brric is online now
Old 02-14-2012, 05:04 PM   #66
Originally Posted by brric View Post
No kidding?
If you knew all that then what was the point of this:
jasin is offline
Old 02-14-2012, 05:08 PM   #67
Master Electrician
The point was that your belief that ground rods provide a low resistance electrode is many times incorrect.
brric is online now
Old 02-14-2012, 05:15 PM   #68
Please stop making stuff up!!!!!!!!!! I never said any one grounding system is low-resistance or lower resistance in comparison to another. I only stated the grounding system should be low-resistance, below 25ohms, as this is what's required by code.
jasin is offline
Old 02-14-2012, 05:17 PM   #69
Originally Posted by plummen View Post
Now ya notice Brric's avitar says master electrician,Ive got a few licenses,Speedey Petey is licensed,Jim Port is licensed.........?
Are you catching a pattern here Jasin?
I'm going to continue to stand by my, do it right to begin with.
jasin is offline
Old 02-14-2012, 05:17 PM   #70
Sparky
Rewards Points: 510
But it's only required to be below 25 Ohms if you're using a single rod.
Drive a 2nd and nobody cares what it is, it could be 2000 ohms..
Techy is offline
The Following 4 Users Say Thank You to Techy For This Useful Post:
brric (02-14-2012), Jim Port (02-14-2012), mpoulton (02-15-2012), Speedy Petey (02-14-2012)
Old 02-14-2012, 05:43 PM   #71
Rewards Points: 214
Jasin,
I'm going to go ten feet with the second ground rod simply because that puts it directly under my phone and satelite entry boxes/ground wires.
Siemens and some others (maybe Mike Holts) depict and/or recommend installing the additional ground rods in close proximity of such equipment. It's won't cost but a few dollars more so no biggie.
I did not realize ground rods were supposed to be driven completely underground though! Virtually every ground rod I've ever seen in Alabama and Mississippi are all clamped just above the surface. Is that a new code?
Thanks.
P.S. Much of this has been hashed over already so maybe better to let some points rest.
Now back to
Ralph III is offline
Old 02-14-2012, 08:13 PM   #72
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I'm not using google i'm using my brain. Nevertheless, the equation is: R=2paR
Not hardly ..... I would suggest 'grounding' google ...
Though it has been entertaining I would suggest that all the BS come to an end.
No one here ..including me... has any business trying to pass themselves off as someone who knows anything about soil resistivity testing, ground rod resistance or what is actually considered a low resistance ground for purposes of equipment protection like computers and entertainment systems.
These calculations are done by engineers using computer software to deal with the math. It is involved ... to say the least. Which is why they have test equipment for field use ...
You are very limited as a home owner as to what you have the capability to accomplish. Unless your pockets are giant deep.
You cannot reach levels of low resistance of 2 or 3 ohms which is required in order to have maximum capabiltiy to protect sensistive equipment with 8' ground rods. In fact your going to be lucky to have 25 ohms average resistance for multiple rods. You might not be able to get below 100 ohms. So adding ground rods by more than 2 may not gain you a dang thing.
To get this so called low resistance you would need to get your ground rods 30 feet deep or more. I understand you can use a variety chemicals poured in the bored hole after setting a ground rod to increase soil contact which will also help for a shallow driven ground rod....30 feet or less.
Also remember lightning doesn't much care about ground rod resistance or soil resistance it will overcome it easily. So about all you can do is protect your home from transient voltages and power company surges and proximity lighting strikes that are containable with the technology available to a home owner. Many of these events you will not have anything that is going to save the day so to speak.
You need also remember the NEC did not have in mind saving your electronics by augmenting with grounding rod or rods. They were wanting premise system grounding to protect your homes wiring and keep the spikes within the insulation of your wires and a few other concerns like potential differences on metal and voltage stabilization in the event of a lost service neutral..
Now the brief summary I'm posting has nothing to do with my knowledge ... I'm sitting here reading over some books I have (some old some new) on achieving a low resistance ground for the protection of sensitive equipment. And it is apparent to me you are very limited in accomplishing that with shallow driven ground rods.
Just my two cents worth.
Stubbie
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Stubbie is offline
The Following 9 Users Say Thank You to Stubbie For This Useful Post:
brric (02-14-2012), davido30093 (02-14-2012), jbfan (02-14-2012), JetSwet (02-15-2012), Jim Port (02-14-2012), KStatefan (02-14-2012), mpoulton (02-15-2012), plummen (02-14-2012), Speedy Petey (02-14-2012)
Old 02-14-2012, 09:31 PM   #73
Registered User
Rewards Points: 5,520
Well, that wraps up another one when a few can't play together it ruins it for the rest.
OP, if any more questions, please start another thread, thank you, Gary
Gary in WA is offline
Closed Thread
Multiple Grounding Rods hayashi Electrical 22 11-30-2011 02:54 AM
New detached garage with sub and ground, house has no ground at panel italie Electrical 9 09-12-2011 02:43 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
Bonding Ground in Conduit jamiedolan Electrical 5 01-26-2010 10:14 PM
